cb fuse location on a t680 kw an number
Discussion in 'Kenworth Forum' started by daveray1960, Apr 14, 2015.
  1. daveray1960
    daveray1960 Bobtail Member
    Need to find the location of the fuse that control the cb in the kw t680. So I can replaced it the one come with the cb is good so it's the truck fuse I try another radio and it won't come on either
  3. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    pete and KW are kinda similar, did you check the fuse panel UNDER the clutch pedal? usually there
  4. daveray1960
    I know where the fuse box is I just need to know wich on is for the cb harness.
  5. Lyle H
    Lyle H Road Train Member
    1,291
    2,938
    Apr 16, 2014
    Pull the cover off and look at the diagram. It's not that difficult.
  6. daveray1960
    I would if had one. But that's ok i went to a kw dealer and got a picture of it so I can fix it and it fix.thank you
  7. mr.travo
    mr.travo Bobtail Member
    49
    13
    Aug 20, 2014
    SC
    I just popped mine the other day. I "think" it was number 34 or 36. I can't recall. Did you get it swapped out yet?
  8. Karl Matthews
    Karl Matthews Bobtail Member
    11
    Oct 13, 2015
    I just had the fuse for the CB blow in my T680. However, when I looked at the diagram on the inside of the panel cover, the one for the CB was marked R7. Because of all the plastic panels under there, I couldn't find R7. When you're looking straight at the fuse panel, could you tell me where the fuse, that you changed, is located please ?
    Thank you, and have a Blessed day.
