CB Cobra 29 NW LTD Classic
Discussion in 'CB Radio Forum' started by Jughead0331, May 21, 2019.
  1. Jughead0331
    Jughead0331 Bobtail Member
    4
    Hey guys, I'm running into a problem with the truck sound running into the cb. I have it hooked straight to the battery and tried different grounds but I can't get it to stop bleeding over into the cb. As I give the truck more gas the more the sound is. Any help would be appreciated.
  3. wolverine11
    wolverine11 Road Train Member
    1,629
    1,234
    Apr 1, 2015
    What kind of truck ? I drive a 2020 T680 and when using President Mckinley radio I can hear rpm' s increasing or decreasing, the transmision shifting ( auto pos) its quite annoying, strange though its not that noticable with a Cobra 29, dont know if it has better filtering or less sensitive receive.
    Slowmover1 and Jughead0331 Thank this.
  4. Jughead0331
    4
    This is in my personal vehicle, Chevrolet Dually. It never did this in my Freightliner
  5. wolverine11
    1,629
    1,234
    Apr 1, 2015
    Remove the antenna and see if you still hear it and try to pinpoint the source, coming throught power cord or antenna.
  6. Slowmover1
    Slowmover1 Road Train Member
    1,491
    1,209
    Oct 25, 2015
    Fort Worth
    Fuel pumps are first to suspect. Then coil-on-sparkplug ignition.
    See the mobile amateur radio bible:
    www.k0bg.com
    rabbiporkchop and Jughead0331 Thank this.
  7. wolverine11
    1,629
    1,234
    Apr 1, 2015
    Correction: The new T680 ( 2020) that I just moved into , the Mckinley is not picking up engine noise like it did in the previous T680( 2019) dont know why but Im glad.
  8. 2Charlietango156
    2Charlietango156 Bobtail Member
    10
    14
    May 23, 2019
    My shop
    Where have you been grounding your cb in the dually
  9. Jughead0331
    4
    Battery
  10. 2Charlietango156
    10
    14
    May 23, 2019
    My shop
    Try making a shorter ground to inside of truck. Shorter wire means less RF
    Also look up choke insalators.
    You may have to install a CPL on your power line going to your battery
    If not then it's your alternator . It's a harder thing to ground it.
    While your at it go ahead and run a ground to wiper motor. 90% of us who run wipers hear it in the radio when it's raining.
    Vehicles in general esp trucks (Chevy) are bad at bieng grounded from the factory. Your truck is your ground plane.
    Make sure your ground wire is short on your antenna mount.the longer it is the more it acts as a radial which that's not what you want.you want RF ground
    Jughead0331 and rabbiporkchop Thank this.
  11. Ridgeline
    22,108
    113,242
    That's exactly what you want, you want a balanced antenna.
