CB antenna for newer "plastic trucks" question
Discussion in 'CB Radio Forum' started by subpartrucker, Mar 10, 2012.
  1. subpartrucker
    subpartrucker Light Load Member
    77
    19
    Nov 21, 2010
    Upstate/Central NY
    I've read some posts here about SWR issues with some of the newer "space aged" trucks like the Freightliner Cascadia...I was just wondering would a "no ground" antenna be a solution? they make them for boats and RV's.
    example: http://www.radioshack.com/product/index.jsp?productId=2062086
    I was just curious if this would be a possible solution.I'm a yard guy now,but if I was still out there and was in one these newer space aged trucks,I might look into something like this.
  3. Xcis
    Xcis Medium Load Member
    498
    270
    Jul 9, 2008
    Bridgeport, Pa
    If you go to the Francis antenna website they have a CB Antenna Ground Plane Kit for trucks. www.FrancisAntennaOnline.com/cb_antenna_mounts.html
    .These newer trucks that have the AM/FM radio and CB radio using the same antenna are receiveing some bad reviews. You may want to give serious consideration to running your own separate coax cable just for the cb radio.
  4. subpartrucker
    77
    19
    Nov 21, 2010
    Upstate/Central NY
    I was just curious...for me personally I don't need it,I've read a few posts about poor SWR and poor grounding issues and thought maybe a "no ground" antenna could be a possibility to solve the problem.
  5. rollingradios
    rollingradios Light Load Member
    184
    66
    Mar 9, 2012
    Richmond, Va
    The no grounds work, but poorly.
    XCis, those ground plane kits are great lookers, but trust me that's it.
    I've actually had decent luck with 3' and 4' K40 super flex on driver's side of these trucks as long as the internal coax isn't shorted or poorly connected. Is it great, no. Is it usable without harming your radio, yes. Usually about 1.7-1.8 swr or a little better. Yes there's other ways for better performance but this will work reasonably well.
  6. Jason Brewer
    Jason Brewer Bobtail Member
    South Central pa
    I've never had good luck with radio shack antennas for cb. their TV antennas on the other hand can't be beat!
  7. kc0iv
    kc0iv Light Load Member
    294
    233
    Mar 31, 2010
    Parkville, Mo
    Over the years I've nothing but good luck with their (Radio Shack) 102" CB whips.
    I've cut several of them down and used them on both 10 meters and 6 meters as well as using them on 27 mhz.
    Leon
    (kc0iv)
    WA4GCH Thanks this.
  8. mike5511
    mike5511 Road Train Member
    3,139
    1,523
    May 15, 2011
    NW Arkansas
    This has been my experience as well.
    One would be wise to thoroughly check the coax and all connections (doing away with all connections except at the antenna and radio would be even better) on all these new trucks before even attempting to install a radio.
  9. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    A 102 inch wip is a 102 inch wip no matter who makes it ... I just gave away my last one cut for 29.600 nothing wrong it was too much for my trunk mount ....
  10. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    THROUGH THE GLASS ARE EVEN WORSE ... :biggrin_25513:
  11. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    Yop, them cascadia's are all plastic and have no ground plane in them at all.
    [ame="http://www.youtube.com/watch?v=Q2PC-NFEq04"]video[/ame]
