Caught On A "NO TRUCKS" Road?
Discussion in 'Trucker Legal Advice' started by Tanksmuch, Dec 22, 2020.
  1. Tanksmuch
    Tanksmuch Light Load Member
    102
    181
    Jul 22, 2019
    Central Arkansas
    Depends on where the sign is... I beat a ticket like this, but it was weight restricted.
    It's called Selective Exclusion and below is a clip from the MUTCD (Federal Guidelines).
    Support: 03 Typical exclusion messages include: A. No Trucks (R5-2), B. NO MOTOR VEHICLES (R5-3), C. NO COMMERCIAL VEHICLES (R5-4), D. NO TRUCKS (VEHICLES) WITH LUGS (R5-5), E. No Bicycles (R5-6), F. NO NON-MOTORIZED TRAFFIC (R5-7), G. NO MOTOR-DRIVEN CYCLES (R5-8), H. No Pedestrians (R9-3), I. No Skaters (R9-13), J. No Equestrians (R9-14), and K. No Hazardous Material (R14-3) (see Section 2B.62). Option: 07 The Selective Exclusion sign should be placed on the right-hand side of the roadway at an appropriate distance from the intersection so as to be clearly visible to all road users turning into the roadway that has the exclusion.
  3. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    What, you mean that no trucks sign shouldn't be halfway down the block behind a tree?
  4. Tanksmuch
    102
    181
    Jul 22, 2019
    Central Arkansas
    LOL, sure, if they want to ticket me... I'll be glad to fight it because that's the d'head I am. ;)
  5. MACK E-6
    48,113
    219,509
    Of course none of that matters if you land in front of a anti-truck biased judge.
  6. bryan21384
    bryan21384 Road Train Member
    14,483
    30,973
    Sep 18, 2009
    Memphis, TN
    Well.....if you avoid those roads then you won't have to fight that ticket now will you?
  7. God prefers Diesels
    4,198
    22,258
    Jun 26, 2020
    South Texas
    Every single road I've went on that was restricted completely, or restricted to 58,280, isn't in the atlas as a restricted road. Other than just knowing the route, what do you do? Call the local PD and tell them your route and see if it's all kosher?
  8. MTN Boomer
    MTN Boomer Road Train Member
    1,157
    1,960
    Feb 4, 2019
    I was permitted on a F m road in Texas, my GPS said it was restricted. No sign, did a load a day, one day a sign with the weight limit apeared. Changed the route.
  9. bryan21384
    14,483
    30,973
    Sep 18, 2009
    Memphis, TN
    I think those are ok, but those roads that have the obvious no trucks sign, like going through neighborhoods or maybe certain downtown areas, are the ones i speak of. Louisiana and Mississippi will have those 58000 weight limit signs but they are ok usually. Some drivers are a little too reliant on their GPS, especially a 4 wheeler GPS, and it over simplifies routes. Then it gets truckers on ill advised routes. Many of those will have that restricted sign, like the parkways in NYC
  10. MTN Boomer
    1,157
    1,960
    Feb 4, 2019
    I got a ticket from tree police, I cut through to avoid an road shutdown . I just kept my mouth shut and paid the ticket
  11. Tanksmuch
    102
    181
    Jul 22, 2019
    Central Arkansas
    If the sign is in the proper place, I will certainly avoid the roads. If the sign is on the road that's restricted then it's too late to avoid.
