Caterpillar Engine Serial Lookup
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JimmyWells, Mar 9, 2017.
  1. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    Can anyone look up and post the data for my Cat? 5EK71431
  3. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    JimmyWells and Oxbow Thank this.
  4. Oxbow
    Oxbow Road Train Member
    12,448
    127,832
    Nov 24, 2015
    It says that it is a 3406E, 355 HP @ 1800 RPM, was in a Peterbilt. Build date of 12/22/95, ship date of 01/04/96. I am kind of new with the SIS system, but hopefully this is correct. It gives me all the individual part numbers as well if you need anything.
    JimmyWells, snowman_w900 and SAR Thank this.
  5. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    Thanks. I'd like to know what size turbo is on it and what the HP was set at when it left the factory.
  6. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    Thank you, sir. Are you sure about the HP rating? The data sticker claims it could be 410 to 550. What's the turbo part number?
  7. Belials
    Belials Light Load Member
    232
    214
    Jun 10, 2014
    Built date: 22Dec1995
    Ship date: 04Jan1996
    3406E / C15
    HP 355 @ 1,800 RPM
    Original turbo part number looks to be 130-6233 or a 130-9107. CAT numbers are weird.
    JimmyWells Thanks this.
  8. Oxbow
    12,448
    127,832
    Nov 24, 2015
    No, I'm not sure, and after looking at your tag I would think the that would be the information to use. I just quoted what SIS said.
    JimmyWells and SAR Thank this.
  9. SAR
    2,756
    36,654
    Nov 26, 2011
    ND
    I'm not sure what size or how that turbo flows but looks like part number 0R-7136. You can look at your turbo that is currently on your engine and there should be a tag on it.
    The hp rating on your engine when shipped from factory was 355. It could of been uprated by now, I think the only way to find out what it is currently set at is to hook up to a computer.
    That data sticker you showed is something they put on every engine showing year it was produced and engine serial number. Max hp on that engine can go to 550 hp@ 1800 rpm, is how I am reading it but I could be wrong.
    Oxbow and JimmyWells Thank this.
  10. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    Thanks for the help gentlemen. I had a scanner on it and it claims the engine has been uprated to 525 but the truck does NOT pull like a 525 at all. I'm thinking the uprate is a gutless low emissions CAT tune.
    Oxbow Thanks this.
  11. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    Makes sense but what's the 410 number? I thought that was the number it left the factory with.
    Oxbow Thanks this.
