Caterpillar C-9 fault code list
Discussion in 'Peterbilt Forum' started by elimy, May 20, 2015.
  1. elimy
    elimy Bobtail Member
    I am looking for a list of fault codes for a Caterpillar C-9 truck engine with serial number prefix 9DG. I did find a partial list for a 3176B, C-10, C-12, 3406E, C-15 and C-16. Are they the same for a C-9?
  3. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    No c9 will be different. What code are you having?
  4. elimy
    I am not sure yet. The truck has a check engine light on and is scheduled to come in on Monday. I was hoping to have the list ahead of time to save some downtime once the truck gets here.
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Here's a list of flash codes. This is all the codes for HEUI and EUI, so there are a lot there wont apply to your engine, but all the C9 HUEI codes should be on it.
    FC - DIAGNOSTIC CODE DESCRIPTION
    00 - QUICKSTOP OCCURRENCE
    00 - INLET AIR SHUTOFF SHUTDOWN
    00 - RATED ENGINE POWER SPECIAL INSTRUCTIONS
    00 - BRAKE PEDAL SWITCH #1 FAULT
    00 - BRAKE PEDAL SWITCH #2 FAULT
    00 - OUTSIDE AIR TEMP SENSOR VOLTAGE HIGH
    00 - OUTSIDE AIR TEMP SENSOR VOLTAGE LOW
    00 - OUTSIDE AIR TEMP DATA LOST
    01 - IDLE SHUTDOWN OVERRIDE
    12 - INVALID COOLANT LEVEL
    12 - COOLANT LEVEL SENSOR VOLTAGE HIGH
    12 - COOLANT LEVEL SENSOR VOLTAGE LOW
    13 - FUEL TEMP VOLTAGE HIGH
    13 - FUEL TEMP VOLTAGE LOW
    13 - THEFT DETERRENT ACTIVE
    13 - THEFT DETERRENT ACTIVE WITH ENGINE CRANKING
    14 - RETARDER SOLENOID LOW/HIGH VOLTAGE LOW
    14 - RETARDER SOLENOID LOW/HIGH VOLTAGE HIGH
    14 - RETARDER SOLENOID MED/HIGH VOLTAGE LOW
    14 - RETARDER SOLENOID MED/HIGH VOLTAGE HIGH
    15 - INJECTION ACTUATION PRESSURE - ERATIC SIGNAL
    15 - INJECTION ACTUATION PRESSURE - VOLTAGE HIGH
    15 - INJECTION ACTUATION PRESSURE - VOLTAGE LOW
    16 - HIGH EXHAUST GAS TEMP - DERATE
    16 - VERY HIGH EXHAUST GAS TEMP - DERATE
    17 - EXCESSIVE ACTUATION PRESSURE
    18 - INJECTION ACTUATION PRESSURE - OUTPUT FAULT
    21 - 5 VOLT SUPPLY VOLTAGE HIGH
    21 - 5 VOLT SUPPLY VOLTAGE LOW
    21 - 8 VOLT SUPPLY VOLTAGE HIGH
    21 - 8 VOLT SUPPLY VOLTAGE LOW
    24 - OIL PRESSURE SENSOR VOLTAGE HIGH
    24 - OIL PRESSURE SENSOR VOLTAGE LOW
    25 - BOOST PRESSURE SENSOR VOLTAGE HIGH
    25 - BOOST PRESSURE SENSOR VOLTAGE LOW
    25 - BOOST PRESSURE NOT RESPONDING
    26 - BAROMETRIC PRESSURE VOLTAGE HIGH
    26 - BAROMETRIC PRESSURE VOLTAGE LOW
    26 - BAROMETRIC PRESSURE SIGNAL RATE OF CHANGE
    27 - COOLANT TEMPERATURE SENSOR VOLTAGE HIGH
    27 - COOLANT TEMPERATURE SENSOR VOLTAGE LOW
    28 - ACCELERATOR PEDAL POSITION OUT OF CALIBRATION
    29 - PTO THROTTLE SIGNAL INVALID
    29 - PTO THROTTLE SIGNAL CALIBRATION
    31 - LOSS OF WHEEL-BASED VEHICLE SPEED SIGNAL
    32 - ACCELERATOR PEDAL POSITION INVALID
    34 - PRIMARY ENGINE SPEED LOSS OF SIGNAL
    34 - SECONDARY ENGINE SPEED LOSS OF SIGNAL
    35 - ENGINE OVERSPEED WARNING
    36 - VEHICLE SPEED SIGNAL INVALID
    36 - VEHICLE SPEED SIGNAL OUT OF RANGE
    36 - VEHICLE SPEED SIGNAL RATE OF CHANGE
    37 - FUEL PRESSURE SENSOR - VOLTAGE HIGH
    37 - FUEL PRESSURE SENSOR - VOLTAGE LOW
    38 - INTAKE MANIFOLD AIR TEMPERATURE SENSOR VOLTAGE HIGH
    38 - INTAKE MANIFOLD AIR TEMPERATURE SENSOR VOLTAGE LOW
    39 - NJECTION ACTUATION PRESSURE SYSTEM FAULT
    41 - VEHICLE OVERSPEED WARNING
    42 - PRIMARY TO SECONDARY ENGINE SPEED SIGNAL CALIBRATION
    42 - ENGINE SPEED SIGNAL CALIBRATION NOT PERFORMED
    44 - SECONDAY FUEL LEVEL SENSOR - VOLTAGE HIGH
    44 - SECONDAY FUEL LEVEL SENSOR - VOLTAGE LOW
    46 - LOW OIL PRESSURE WARNING
    46 - VERY LOW OIL PRESSURE 46
    47 - IDLE SHUTDOWN OCCURRENCE
    47 - PTO SHUTDOWN OCCURRENCE
    49 - INLET AIR HEATER - CURRENT LOW
    49 - INLET AIR HEATER - CURRENT HIGH
    51 - EXCESSIVE ECM BATTERY POWER
    51 - LOW ECM BATTERY POWER
    51 - INTERMITTENT BATTERY POWER TO THE ECM
    55 - NO DIAGNOSTIC CODE DETECTED
    56 - CHECK TRANSMISSION CUSTOMER PARAMETERS
    56 - CHECK CUSTOMER OR SYSTEM PARAMETERS
    58 - J1939 DATA INCORRECT
    58 - J1939 DEVICE NOT RESPONDING
    59 - ENGINE SOFTWARE INCORRECT
    61 - HIGH COOLANT TEMPERATURE WARNING
    61 - VERY HIGH COOLANT TEMPERATURE
    62 - LOW COOLANT LEVEL WARNING
    62 - VERY LOW COOLANT LEVEL
    63 - LOW FUEL PRESSURE WARNING
    63 - LOW CRANKING FUEL PRESSURE WARNING
    62 - LOW COOLANT LEVEL WARNING (LESS THAN 6 ENGINE HOURS)
    64 - HIGH INTAKE MANIFOLD AIR TEMPERATURE WARNING
    64 - VERY HIGH INTAKE MANIFOLD AIR TEMPERATURE WARNING
    65 - HIGH FUEL TEMPERATURE WARNING
    66 - AUXILIARY OUTPUT #06 CURRENT LOW
    66 - AUXILIARY OUTPUT #06 CURRENT HIGH
    67 - AUXILIARY OUTPUT #07 CURRENT LOW
    67 - AUXILIARY OUTPUT #07 CURRENT HIGH
    68 - TRANSMISSION NOT RESPONDING
    71 - IGNITION KEY SWITCH FAULT 71
    72 - CYLINDER #1 INJECTOR CURRENT LOW
    72 - CYLINDER #1 INJECTOR CURRENT HIGH
    72 - CYLINDER #2 INJECTOR CURRENT HIGH
    72 - CYLINDER #2 INJECTOR CURRENT LOW
    73 - CYLINDER #3 INJECTOR CURRENT LOW
    73 - CYLINDER #3 INJECTOR CURRENT HIGH
    73 - CYLINDER #4 INJECTOR CURRENT LOW
    73 - CYLINDER #4 INJECTOR CURRENT HIGH
    74 - CYLINDER #5 INJECTOR CURRENT LOW
    74 - CYLINDER #5 INJECTOR CURRENT HIGH
    74 - CYLINDER #6 INJECTOR CURRENT LOW
    74 - CYLINDER #6 INJECTOR CURRENT HIGH
    92 - INTAKE VALVE ACTUATOR #1 CURRENT LOW
    92 - INTAKE VALVE ACTUATOR #1 CURRENT HIGH
    92 - INTAKE VALVE ACTUATOR #1 NOT RESPONDING
    92 - INTAKE VALVE ACTUATOR #2 CURRENT LOW
    92 - INTAKE VALVE ACTUATOR #2 CURRENT HIGH
    92 - INTAKE VALVE ACTUATOR #2 NOT RESPONDING
    93 - INTAKE VALVE ACTUATOR #3 CURRENT LOW
    93 - INTAKE VALVE ACTUATOR #3 CURRENT HIGH
    93 - INTAKE VALVE ACTUATOR #3 CURRENT NOT RESPONDING
    93 - INTAKE VALVE ACTUATOR #4 CURRENT LOW
    93 - INTAKE VALVE ACTUATOR #4 CURRENT HIGH
    93 - INTAKE VALVE ACTUATOR #4 CURRENT NOT RESPONDING
    94 - INTAKE VALVE ACTUATOR #5 CURRENT LOW
    94 - INTAKE VALVE ACTUATOR #5 CURRENT HIGH
    94 - INTAKE VALVE ACTUATOR #5 CURRENT NOT RESPONDING
    94 - INTAKE VALVE ACTUATOR #6 CURRENT LOW
    94 - INTAKE VALVE ACTUATOR #6 CURRENT HIGH
    94 - INTAKE VALVE ACTUATOR #6 CURRENT NOT RESPONDING
    95 - LOW INTAKE VALVE ACTUATION SYSTEM OIL PRESSURE
    95 - INTAKE VALVE ACTUATION OIL PRESSURE VOLTAGE HIGH
    95 - INTAKE VALVE ACTUATION OIL PRESSURE VOLTAGE LOW
    97 - INTAKE VALVE ACTUATION SYSTEM OIL PRESSURE SOLENOID CURRENT LOW
    97 - INTAKE VALVE ACTUATION SYSTEM OIL PRESSURE SOLENOID CURRENT HIGH
    97 - INTAKE VALVE ACTUATION SYSTEM OIL PRESSURE NOT RESPONDING
    98 - ENGINE COOLANT DIVERTER SOLENOID CURRENT LOW
    98 - ENGINE COOLANT DIVERTER SOLENOID CURRENT HIGH
    elimy Thanks this.
  6. elimy
    This is exactly what I was looking for. Thank you.
  7. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    BTW, Cat flash codes are fairly consistent across any engine from the PEEC right up until they stopped using flash codes. Each engine had it's own set of fault codes that it uses (none of them use them all), but engines that have the same flash code have the same fault description for that code. For example, flash code 24 is an oil pressure sensor fault, no matter what engine.
    If you can't find a specific flash code for your engine, but found that same flash code for another Cat engine, chances are that it's the same fault description.
  8. Shaggy76
    Shaggy76 Heavy Load Member
    831
    307
    Feb 22, 2012
    Orlando, FL
    The codes tend to line up across most engines anymore. The engineers association did this to make it easier fore technicians.
