Caterpillar and emissions
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by spindrift, Sep 5, 2019.
  1. spindrift
    spindrift Road Train Member
    3,233
    12,905
    Dec 2, 2014
    Texas
    There are folks advertising 2005 and 2006 trucks with the C15 and saying these are no/pre emission engines. I've always been under the impression that once Cat went to the dual turbo engine, it's considered an emission engine. What am I missing?
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    An emissions engine is one with the DPF. So 2007 and newer.
    Oxbow Thanks this.
  4. AModelCat
    154,580
    I consider anything with EGR an emissions engine. CAT's Acert was their solution to meeting the emission standards of those years without resorting to EGR.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Before EGR was pre-emissions, 2003 was the transition year. EGR was bad enough, DPF was worse. Things started to get better once DEF came out as they began to cut back on EGR.
  6. spindrift
    3,233
    12,905
    Dec 2, 2014
    Texas
    The C15 was available in 2006, just before the Acert came out. It has a dual turbo which was the beginning of Cat's attempt to meet tougher emission standards. Was it only the Acert with the dual turbos where things got out of control with ECM tuning?
  7. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    CAT used valve timing with the use of VVA's to control Nox versus EGR on the twin turbos Acerts. Then with the addition of DPF's on the SDP and LEE engines clean gas induction was added because the VVAs alone could not reduce the NOX enough.
  8. spindrift
    3,233
    12,905
    Dec 2, 2014
    Texas
    So I shouldn't be concerned about a C15 with twin turbos?
  9. Cattleman84
    Cattleman84 Road Train Member
    9,871
    70,312
    Nov 1, 2017
    The Sticks, Idaho
    If I'm not mistaken there are alot of good tunes for those engine... But I have no personal experience with them myself
    spindrift Thanks this.
  10. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Mine had 1.5M when I sold it, still ran strong and oil samples still looked good. The IVA valves are a known problem with them I would lose maybe one a year. Sometimes it was just the wiring going to it that was bad. The best way to tell if you have one out is your turbo pressure all of the sudden won't go past 30# of boost. It's a safety feature built into it to prevent damage.
    Oxbow, Intothesunset, A5¢ and 2 others Thank this.
  11. AModelCat
    154,580
    Pretty sure Acert came out after the MBN (bridge engine). So would have been around the 2003 engine year.
    Oxbow, Intothesunset and A5¢ Thank this.
