Caterpillar 5EK pros vs cons????
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by OLDSKOOLERnWV, May 27, 2023.
  1. OLDSKOOLERnWV
    20,024
    302,472
    Quick question guys, guy just called me about trading a 1994 W900L with a Caterpillar 5EK, I’m clueless to the engine…
    Any pros or cons from those that are familiar with that engine…?
    Said it has a 13 spd and something came loose in the trans affecting the output yoke…
  3. Gilbyson
    Gilbyson Light Load Member
    50
    62
    Apr 26, 2012
    Wyoming
    IIRC its the best version of the 3406E. 5ek is 3 of the engine serial numbers.
  4. beastr123
    beastr123 Road Train Member
    2,988
    24,601
    Jan 2, 2014
    Moose Jaw SK CAN
    @wore out
    Sons Hero, OLDSKOOLERnWV and Oxbow Thank this.
  5. Star Rider
    Star Rider Road Train Member
    1,894
    21,842
    Sep 23, 2019
    5EK was known for breaking cranks. Changing the harmonic balancer at regular intervals is like maintenence for them to prevent it
  6. wore out
    wore out Numbered Classic
    18,261
    231,544
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    They were known for breaking cranks. However the crank they replaced the broken one with fixed that issue. If it hasn’t broken a crank by a million then it didn’t have one of the bad ones. Any engine past a million anything goes we all know that. The bad cranks had to die with a strike at the engine plant I’m pretty sure I’ve heard the story when I worked for Riggs in Little Rock but can’t remember enough of it to recite it.
    Jim I personally like the 5EK. I know of 3 that I’d put against anything in terms of dependability, economy etc. now these guys don’t have them “tuned” and beat on em. They all have a factory 550 ECM. Trim files match what’s on the injector run factory turbos and are well maintained. They do an excellent job. Like anything with lots of miles you have to watch the lower counterbores for too much wear possibly have them sleeved. And watch liner potrusion at the top like we’ve talked about on your B model. I wouldn’t be a bit scared of one. Unless they made big power with it at one time or currently. They will crank the block horizontally above the oil pan rail around prolonged use at 700 or better. Just go look at with the same approach you would anything else and you’ll be fine
  7. Last Call
    Last Call Road Train Member
    7,568
    45,916
    Mar 15, 2021
    One of the few friends I have .. has a couple 5EK's he bought 1 with about 350k on it the other one had close to 500k.. he has extra stupid files in them their both set at about 660 or 680. He don't baby them but he don't whip em into the ground either.. He drives em with common sense and has never had a issue in the 8 or 9 years I think he's owned them.. We put new fuel squirter's in the lower milage 1 this last winter cause 1 was weak when we ran the cut out test.. I think it has about 680k on it now its on the books for a OH sometime later this summer just because of the milage on it .. the other 1 was OH about a year after he bought it because of oil consumption .. but they both have the original crankshafts in them
    like @wore out said they can make some dependable HP ..
    I would own 1 and not be scared.
    But you.know me I like my mechanicals
  8. OLDSKOOLERnWV
    20,024
    302,472
    Thank you…
    Didn’t get to go look at it today, it’s only about 7 miles away from what he told me.
    Said it had daylight doors which is a big negative to me lol. Not sure I’d keep it but the bigger sleeper and newer engine got my interest.
    This 379 in the pic was my Rig Tender we built at R&L Drilling, it was a 97 model with a Cat and 18 spd, it performed very well. The 98 379 is what I pulled the beam trailer with after we sold the binder, the 98 had a 525 N14, both good trucks far as I was concerned….
  9. Diesel Dave
    10,080
    35,847
    Jan 20, 2010
    Hesperia, Ca.
    My former 1994 379 had a 5EK. I had a tune in it with a stage one turbo, best engine I’ve ever owned and still got 7.0 mpg.
  10. OLDSKOOLERnWV
    20,024
    302,472
    Little extra fuel mileage would be a plus for sure. Best I’ve got is 5.25 @ 80,000 running 65 mph through Indiana. That was with the big pump…
  11. Big Road Skateboard
    7,837
    45,564
    May 2, 2021
    Did you know Kenneth Driggers? Think that was his name. Worked at Riggs in LR
