Cat water pump
Discussion in 'Trucks [ Eighteen Wheelers ]' started by morehp, Mar 16, 2013.
  1. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    Anyone ever fitted mxs,nxs,sdp water pump to 6nz ? Pretty sure they are higher flow, something I've thought about for a while , may help high hp application's with cooling
  3. HISPEED428
    HISPEED428 Light Load Member
    157
    21
    Mar 28, 2009
    Plum Coulee,MB
    A friend of mine with a C16 built by PDI say's they installed the water pump from his MXS or NXS onto the C16.
    morehp Thanks this.
  4. morehp
    699
    206
    Jun 18, 2012
    If they did it I'm thinking I'm right , did he notice any difference ?
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    yep it can be done. you have to change the thermostate outer housing and the water plate that goes on the back of water pump and im not sure but may have to change the neck that goes to the oil cooler also. but from what i have seen it doesnt make much of a difference in water temp. just curculates the water faster.
    morehp Thanks this.
  6. morehp
    699
    206
    Jun 18, 2012
    Here is some thermostat information for you all, many of you running the 248-5513 ?
    248-5513
    Start to open @ 178f = 81.1c
    Fully open @ 198f = 92.2 c
    247-7133
    Start to open @ 189 f = 87.2c
    Fully open @ 208 f= 97.7c
    black_dog106 Thanks this.
  7. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    thats good to know i assume one is the 180's and the other is the 190 stats?
  8. morehp
    699
    206
    Jun 18, 2012
    Thats when they start to open yes
  9. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    learned something from mr.(guru) about thermostats. i used to run 180's now i run 190's they maintain temp more evenly than the 180's. or that's what i've seen in this new engine. but i'll see what happens this summer when it gets hotter out.
  10. morehp
    699
    206
    Jun 18, 2012
    Yes it's coming out of summer here and I'm seeing a few issues with making reasonable power
  11. morehp
    699
    206
    Jun 18, 2012
    Haven't taken the time to look at c18 water pump and t stat housing anyone know the flow difference between c15 ? or the size of the hose that goes from pump back plate to t stat housing ?
