I am looking at a 06 KW W900. It has a CAT C15 twin turbo. We took it to our mechanic to see if its worth it in the long run. The mechanic said it has alot of blowby. Is this normal for the motor or signs of it going south. The dealership says its normal but the guy is a salesman and just trying to move trucks off the lot.
Thanks for the help
cat twin turbo question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by liftedtrucks4me, Mar 3, 2011.
Page 1 of 3
yes it is normal, as long as its not leaving a big puddle of oil from the blowby tube it is fine, how many miles are on it? get the warranty history pulled from cat also.
Alot of blow by is normal for this motor. Cat sells a kit for these motors to solve some of the oil issues with the blow by, my motor has it but i still have blow by and some oil comeing out but not nearly as bad as it was.
The only way to say if this motor has excessive blow by, is to put it on a dyno and measure the amount of blow by under full load. These engine will huff a considerable amount of blow by while idling. The engine rings are designed to work against cylinder pressure and seal the blow by off under load. CAT has had many complaints about excessive blow by on these engines. CAT also came out with a catch can/oil separator arrangement to install on the crankcase vent tube to catch the excessive oil and return it to the oil pan
I presently own a '06 t600 with a c15 twin turbo. love it. it has blow by but not enough that you would have to add any oil in between you reg interval changes. It does however collect on the steering axle in the winter and then make a mess in your shop when it thaws. making sure they spray axle well when washing truck alleviates this. again great engine great fuel mge.
Page 1 of 3
