Cat throttle position sensor for Peterbilt
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by ODR, Mar 25, 2021.
  1. ODR
    ODR Light Load Member
    66
    48
    Sep 30, 2013
    Tompkins, Sk
    Throttle in my 05 379 with a C15 is intermittently cutting in and out. I talked to my local Peterbilt dealer and was quoted $1400. They gave me a part number and suggested for me to look into an aftermarket part. I have been searching and phoning around but haven't had any luck. I was wondering if anyone had some better leads. Thanks in advance.
  3. Adamali21
    Adamali21 Light Load Member
    278
    179
    Jul 24, 2018
    Is your problem a throttle position sensor or something else
  4. Adamali21
    278
    179
    Jul 24, 2018
    What’s the part number
  5. Farmtractor9900
    Farmtractor9900 Light Load Member
    162
    433
    Nov 6, 2020
    I have a brand new one still in the box for a 2000 379 C15. What's the part number?
    baha Thanks this.
  6. Farmtractor9900
    162
    433
    Nov 6, 2020
    Did you check the three-wire connection going to the throttle?
  7. ODR
    66
    48
    Sep 30, 2013
    Tompkins, Sk
    351733WIL I checked battery connections, cables and wires from throttle. Also made sure fuses were good with no corosion. My mechanic was leaning hard on throttle being the problem although electronics are not his strong point on account of his age but don't tell him that. Lol
  8. Farmtractor9900
    162
    433
    Nov 6, 2020
    I'll see if it's the same part number as the one I bought.
    My intermittent no throttle response ended up being the connection.
  9. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    You were likely quoted a whole throttle pedal. Ask if the sensor is available seporate. OE sensor should only be 2-300 cocos.
    BoxCarKidd, pushbroom and Shawn2130 Thank this.
  10. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    Sounds like not asking that question has cost me a few thousand dollars.
    Thanks for sharing.
