I am the 2nd owner of my 2005 Pete 379
I would like to reprogram my Cat Messenger to put insert my name and make some changes.
Does anyone know how I go about doing this?
I have not had any luck finding a manual for it online.
thanks
[/URL][/IMG]
[/URL][/IMG]
Cat Messenger Display - Help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by wagasser, May 18, 2014.
Thank you. That is very helpful.
But looks like I can't reset the device without having Electronic Service Tool ?
That stinks -
I have CAT messenger. Newer engines like acert twin turbos have awards stuffs on it. I don't know if someone knows about awards.
Thanks
I really want to reset mine as there is only room for 2 drivers to be installed and both are full and not mine. And I would like to use the Theft Detergent Feature as well that is locked up.
Thanks -
Accessing Theft Deterrent
ECM Customer Programmable parameters
determine the access to this function of the dash
display and the Theft Deterrent password. The
ECM must be programmed to allow access to this
screen. The ECM must be programmed or the
entire Theft Deterrent column of the screen map
will not be shown. Pressing the Right arrow key
on the DIAGNOSTIC DATA title screen will cause
the display to pass over the THEFT DETERRENT
title screen.
After the parameters are programmed in the
ECM, the power must be turned OFF and the
power turned ON again in order for the display to
recognize the change. -
russtrucker Thanks this.
When in vocational school, we had c-15 bxs 475 hp that has the messenger on it. It used to be on international according to AR number and it had the reward stuff. We also have a sdp c-15 engine. I don't know if that engine needs the messenger.
