CAT head pressure testing
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Pound Puppy, Sep 19, 2013.
  1. Pound Puppy
    Pound Puppy Heavy Load Member
    974
    868
    May 31, 2010
    Amherst, OH
    How long does it take to do the actual pressure test on a head? Mines in the shop for a blown head gasket.
  3. Shade Tree
    Shade Tree Light Load Member
    177
    44
    May 15, 2011
    Galloway Ohio
    CAT doesn't do head pressure testing. They usually have the head decked and checked for cracks in side of the exhaust and intake ports. They also should check the valves for stem wear. If the truck has a lot of miles it is better money to get a REMAN CYL head. This way you get a warranty. You don't say what kind of CAT engine but they normally leak because of the head bolts stretching or if it is a 3406E and has a aluminum spacer plate the compression has a tendency to a problem just because of the aluminum compressing. Almost all of the CAT engines fared well with the steel spacer plates. if the block is etched because of the head gasket leaking it may need to have that cylinder removed and the deck cut for a shim.
  4. Pound Puppy
    974
    868
    May 31, 2010
    Amherst, OH
    I have a C 15 with 625k on it. They found five cracks. I dont abuse my truck, I keep a strict maintenence schedule. Ive never had this happen before. Only put 50k on since I bought it. Fortunately I bought the extended NTP warranty, it will cover all but the water pump. We are trying to get the pump covered as premature failure because the corrosives leaked in the coolant from the gasket and head failure. Still waiting for the verdict on it. Had to replace all my hoses, including the apu hoses. They were brittle from the corrosives.
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    um, yes they do pressure testing. but it is a flawed test. cat reman heads are a shot in the dark anymore for quality.
    cetanediesel Thanks this.
  6. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    if the cracks are in between the valves and injector area. some cracking is normal. depending on the severity of the cracks. what corrosives are you talking about?
  7. Gasienica
    Gasienica Heavy Load Member
    924
    528
    Sep 7, 2011
    Think he's talking about the exhaust gases.
  8. Shade Tree
    177
    44
    May 15, 2011
    Galloway Ohio
    I rebuilt a lot of CAT engines for head gasket failures, and never had to take into consideration damage from exhaust gases getting into the cooling system. The problem from head gasket failures is compression getting past the head gasket seals.
  9. Superhauler
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    seams like when they started cutting the relief cuts that all the gasket failures started adding up. got lucky and found a head that didn't have the relief cuts, keepin my fingers crossed!
