Just purchased a new transfer pump 316-6863, was wondering if the new updated spring would be installed or would I need to purchase this also.
cat fuel pump upgrade
Discussion in 'Trucks [ Eighteen Wheelers ]' started by upallnite, Dec 6, 2012.
whats the numbers on the stronger spring?
is this something a guy with some mechanical knowledge can do in their driveway? do u get the spring from the dealer or can it be gotten aftermarket?
The new spring can be a pain to get the threaded nut back on.
this new spring will boost the fuel pressure to where it should be for a factory 550? im always looking to see if i can get better fuel mileage. i have the fuel and boost wires on and they seemed to have helped some. at least till the winter fuel started.
went to get the 316-6863 pump and 339-4983 spring kit yesterday. The pump has been updated to 384-8611, this pump comes with the 339-4983 spring installed. before install pressure at idle 75-76 @ 1900 89-90. after install idle 81-82 @ 1900 99-101. It was an easy driveway install. This was on a 6NZ
black_dog106 Thanks this.
