My cat et connects to mxs/sdp but wont connect to a 3406e? Is there a difference in cat et version or something else causing not to connect?
I have even connected to a ISX through same adapter.....
Thanks...Darrell
Cat ET wont connect..?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dr1c, Sep 7, 2012.
try to use J1708))))) old rigs had no J1939
I can connect through dearborn diagnostic link but cat et wont.....can you change it in cat et?
Like Pablo said you'll need to reselect your interface for a 1708 connection. I can't remember exactly, but yes, there is a setting with ET that needs to be switched over. It will be under "Options", or "interface" or "Protocol", something like that.
