Cat Cooling Fan Issues...Again
Discussion in 'Trucks [ Eighteen Wheelers ]' started by silver dollar, Aug 23, 2012.
  1. silver dollar
    silver dollar Medium Load Member
    481
    210
    Jan 31, 2009
    Central North Carolina
    Is there something about Cat engines and cooling fan problems? A few weeks ago I had a problem with my 97 Volvo 3406E; the fan would not come on. So I put in a switch to turn it on when needed. Now i have this 2002 International with the opposite problem. The fan cycles off and on about every 3 minutes. 3 on; 3 off. It does this all the time. Weather idling, road speeds, or A/C on or off. Engine temp never goes above 190*. Anyone have any ideas what is causing this? When I get in this weekend, I plan to take it to a Cat shop and get the ecm read. But I would like to find the trouble to avoid the expense. Thanks.
  3. Ryanr
    Ryanr Light Load Member
    71
    14
    Mar 6, 2009
    ontario
    Cat coolant temp sensor.located on fron.t side of the thermastat housing.35 bucks or so for sensor.it could also be the high pressure ac fan switch.find high pressure ac fan switch bypass the switch.unplug and put paperclip inside.and drive around and see if problems continues.the coolant temp switch will show erratic voltage when you put it on the computer.
    silver dollar Thanks this.
  4. silver dollar
    481
    210
    Jan 31, 2009
    I was peering around trying to see the coolant temp sensor and saw that the insulation on the wires from the sensor was gone for about a half inch. They also seemed to be pinched between the alternator bracket and the thermostat housing. Do you think this may have a bearing on my problem?
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I had a similar prob, turned out to be a bad elec ground.
  6. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    3 mins on and then off is the same default program timing for the fan when the ecm sees A/C high pressure switch input. That should be the red one near or at the compressor. Try to unplug it and see if the fan stays released. The coolant temp sensor that is read by the ecm to control the fan also sends the data to your coolant temp gauge. If the gauge is reading normal the sensor and wiring should be fine. (The insulation needs to be fixed for sure!)
  7. Ryanr
    71
    14
    Mar 6, 2009
    ontario
    i think u said this was in a international?my cats is in a pete so it uses two seperate coolant sensors.One cat sensor for the ecm on the front side of t stat housing and one on top of housing for the gauge in dash (mechanical gage).So if your temp isn't jumping around more then likely its the high pressure ac fan switch, if you just unplug the ac switch the fan will run steady.unplug the harness and jump the harness with paperclip or wire and see if problem continues.
    silver dollar and rollin coal Thank this.
  8. rollin coal
    rollin coal Road Train Member
    13,083
    25,876
    Mar 29, 2008
    TN
    Jumpering the high pressure harness will work but he'll have to stay on top of using the fan manually as needed if he does. I did that and thought it was a bad high pressure switch. Turned out the harness that connected to the high press switch was making poor contact. If he could put a zip tie around it real tight somehow just to see if the connection improves while it's plugged in, and the fan shuts off - get a new harness. Using a paperclip will wallow out where the contacts were made - somebody on here pointed me in this direction when I had a similar problem and they were right on. My fan never would shut off though.
  9. silver dollar
    481
    210
    Jan 31, 2009
    Yes mine is an International with the C15. So far I've only seen one coolant sensor on the front of the housing. So much stuff in the way, and I didn't want to monkey around with it to much on the road. Now my old 3406e had two. I'll check it closer today. Thanks for the tips.
  10. silver dollar
    481
    210
    Jan 31, 2009
    Thanks for this tip. I will check this today. this truck doesn't even have a fan override. I guess I will add it after I solve this problem. Thanks
  11. Ryanr
    71
    14
    Mar 6, 2009
    ontario
    I just went through this.i jumped my ac switch and it was still doin it.so when we put it on the cat computer it was showing eratic voltage for the cat sensor.sometimes the sensor loses its ground.the cat sensor grounds itself to the tstat housing.make sure if it is the sensor and u change yourself torque it to the proper specs.
