Looking to buy a 2006 Pete 335 tandem dump with a c7 cat 275 hp team up with a Allison,500000 km 20000 hrs just wondering are these good engines. Took everyones advice and stayed away from a Mercedes. As always any advise is greatly appreciated Thanks Mike
Cat C7
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Havana7, Apr 25, 2021.
My only experience with cat C7 is school bus applications. They work well until they don't..
Usual failure point is broken piston rings that score the cylinders. These are parent bore engines so they need machine work to repair.
Found them loud, and yellow paint on anything is expensive.. -
Thanks for your response. Can I expect this to happen to this engine with that kind of mileage and hours, also am quite surprised as to how many tandem dumps have c7 in them. Would a Cummins ISC 285 Hp be a better choice in a identical truck both trucks are coming up for auction Thanks again
There is no perfect engine, especially at those miles and hours. It's all about the maintenance and driver. At that mileage and hours you best be planning on repairs...
I've often wondered why the little kittys broke piston rings in school buses. Most I've talked to have blamed the bus duty cycle. Start cold, run like hell for 2 hours. Cool down, and do it again in the afternoon.Last edited: Apr 26, 2021
BoxCarKidd Thanks this. -
Put on about 4000 miles a year short 2 mile trips lots of idling, as I moved ahead every 2 minutes as the excavator loads me
spsauerland Thanks this.
Itsbrokeagain Thanks this.
I’ve got a ‘99 FL60 that I put about a million and 60 something thousand on. The 3126B 250 hp was replaced twice in that time. Original one went around 471,000 and started using a gallon of oil a week. Still ran and pulled ok but wore out. Was normally running 1,300 miles a week.
Second one went almost 500,000 when out of nowhere it dropped a valve and destroyed a cylinder, piston, and turbo.
When I was running it this truck was fired up at 5:30 am and was not shut down till 7 pm 4 days a week or 10 pm one day a week. Hauled 33,000 gross pushing lots of wind running 2400 rpm on highway.
3126/C7 engines blocks are dry sleeves and have to be replaced with new replacement blocks. Crate engines from Cat that were new blocks and remaned everything else were around $24,000 each time.
It’s sister truck is a ‘03 and has a 3126E and is still chugging along for the new owner with around 540,000 on original engine. It never worked as hard as the ‘99 tho.
Fuel injection pumps and injectors were always the weak parts everything else did great for us.Flint1, QUALITYTRUCK and black_dog106 Thank this.
