Cat c15 Turbo upgrade
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MSQUARED, May 10, 2021.
  1. MSQUARED
    MSQUARED Medium Load Member
    334
    484
    Mar 28, 2021
    Hey guys needing a turbo upgrade for C15 Accert SDP engine, Currently running B/W 550 hp wastegated turbo but it's to small. I no nothing about engines on the tech side other then there expensive lol
    Looking for roughly 800hp turbo. I am running just over 600 RWHP according to the dyno with only roughly 26 pounds of boost
    And should I go wastegate or non wastegate and what a/r?
    Beem leaning towards b/w s410-sx
    Thanks
  3. wore out
    wore out Numbered Classic
    15,319
    184,946
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Well what you have for a motor would be a helluva start
    MSQUARED Thanks this.
  4. MSQUARED
    334
    484
    Mar 28, 2021
    Lol was half way in tittle Opps its updated
  5. wore out
    15,319
    184,946
    Jun 5, 2013
    Well is it an acert?
    bridge motor?
    6NZ?
  6. MSQUARED
    334
    484
    Mar 28, 2021
    I updated the first original post, but its an accert sdp
  7. wore out
    15,319
    184,946
    Jun 5, 2013
    82mm Borg Warner in a 1.58 exhaust housing part number ends 0003. Its rated for what your looking for
  8. MSQUARED
    334
    484
    Mar 28, 2021
    This exactly the one Ive been looking at.
    Just curious tho waste gate or no?
  9. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    Not wise to go bigger than stock unless you do injectors and everything else to support bigger. I learned the hard way. Sure you will get more boost and you wont even feel an increase when you hit that boost. All you will feel is a complete turd of a truck becuase it takes forever to spool up. If your motor is all stock, stay with the cat turbo size.
    swaan Thanks this.
  10. MSQUARED
    334
    484
    Mar 28, 2021
    I'm working on it, problem is now I only get about 25 or so. Might be the manifold as well think it has a leak to
  11. wore out
    15,319
    184,946
    Jun 5, 2013
    Don’t be hung up on the boost number,
    you will have to buy an exhaust housing with the 0003. The 1.65 it comes with is not gonna work well with your setup.
    To be clear he asked for a turbo in the 750 range I answered his question.
    swaan Thanks this.
