Cat c15 not building air.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by anthonyar4, Jul 7, 2020.
  1. anthonyar4
    anthonyar4 Medium Load Member
    431
    92
    Jun 8, 2019
    Went down the highway and my warnings came on brakes locked up no air whatsoever. Looked for leak no cut lines. Took off air compressors outlet and it was blowing inconsistent. The guy at the cat shop said it should
    Blow my hand off of it. He said bad air compressor. Any tips? Will not build any air whatsoever
  3. bad-luck
    bad-luck Road Train Member
    3,245
    5,943
    Nov 16, 2013
    Baltimore, Maryland
    If you don't her any audible leaks, and you took the metal braided line off of the back of the air compressor. And it is not blowing any air, inconsistent air, or if you can hold your thumb over the port you need a new compressor
    Shawn2130 Thanks this.
  4. AModelCat
    154,238
    I'd pull the unloader valve in the head and inspect before replacing compressor. Seen them gum up and stick.
    pushbroom, lester, beastr123 and 2 others Thank this.
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    That or simply the air gov went bad.
    lester, beastr123, BoxCarKidd and 2 others Thank this.
  6. anthonyar4
    431
    92
    Jun 8, 2019
    They are manually applying air and it won’t build air. I loser valve?
