Cat C15 blue smoke and blowby
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Vipercat, Dec 13, 2019.
  1. Vipercat
    Vipercat Bobtail Member
    19
    4
    Jul 22, 2019
    I have an 05 NXS twin turbo c15 that has about 935k kms. Truck had blowby when I bought it, and slowly it’s been omitting more and more blue smoke. I can really notice it pouring out when under load in soft ground, goes through a bit of oil but not an insane amount.
    Talked to a mechanic that is going to do the work for me and he figured it was an over fueling injector, or injector o rings. Is this a safe assessment or could it be piston rings.
  3. Mattmanstroked
    Mattmanstroked Light Load Member
    185
    278
    Nov 24, 2019
    Is the blue smoke coming out of the exhaust or the crankcase breather tube?
  4. Vipercat
    19
    4
    Jul 22, 2019
    Hey there, blowby is coming out of the breather tube (slight grey haze but pretty constant)
    blue smoke is coming from the exhaust aswell as underneath the truck, but there’s a few exhaust leaks so I figured it was from there. The blue smoke is not constant, but is getting much more prevalent and thicker.
  5. Mattmanstroked
    185
    278
    Nov 24, 2019
    We have two at work 2006 C15 one with little over a million other with 950,000 miles on them.
    Have not been rebuilt, heads have not been off. Injectors have been replaced on both trucks.
    These are very good engines. I would probably check on getting injectors replaced and see what happens.
    KLAUDEC and Vipercat Thank this.
  6. Vipercat
    19
    4
    Jul 22, 2019
    I’ll have the mechanic look into that once he opens the head up for sure, thanks! Yeah this one doesn’t even have a million kilometres yet and I’ve heard these should last 1 million miles, injectors would be a good replacement
  7. AModelCat
    154,281
    Blue smoke typically means burning oil. Over-fueling is black/grey. If blowby has gotten worse at the same time the blue smoke started, I'd say you've got an oil consumption issue.
  8. DieselTech_Aus
    DieselTech_Aus Light Load Member
    274
    309
    Dec 20, 2017
    WA
    NXS
    are typically bad for blow by and breather smoke. there was an update to put a steel wool canister inline with the breather tube many years ago.
    general rule of thumb. if its puffing, especially from cold start up, you have an issue. if its just a constant haze once running and at operating temp, there is no serious issue.
    if you do rebuild though I would strongly recommend fitting 16:1 comp pistons, ever as a standard ACERT
  9. Vipercat
    19
    4
    Jul 22, 2019
    Yeah the blowby is pretty much a constant, at startup and operating temp.
    The main concern now is the blue smoke from exhaust. It doesn’t all the time but under load it gets pretty heavy between O rings and injectors. It seems blue smoke indicates an oil issue. I’ll definitely look into that 16:1 if I rebuild, thanks for the reply!
  10. DieselTech_Aus
    274
    309
    Dec 20, 2017
    WA
    ACERTS aren't the best for oil consumption and blue smoke.
    I personally use the late SDP prefix rings with the 164xxxx middle ring on 16:1 IPD pistons and don't have issues.
    baha Thanks this.
