CAT C15 6NZ WICH INJECTORS TO GO ???
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Pet379000, Apr 11, 2022.
  1. Pet379000
    Pet379000 Bobtail Member
    12
    Sep 14, 2019
    Hello guy’s,
    I have 2 bad injectors on my 6NZ, thinking to replace all 6. Want to ask you guys as I don’t know much on it. Are the CAT reman’s ok to go this day’s? if not, what can you recommend? It’s a 475hp, will consider go higher, but not much.
    Any feedback will be appreciable….
    Thanks!
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Most all are on back order currently, new or reman. Delphi is the same way. Cat reman have issues, go new if you can afford to. I talked to a rebuilder of them and he is 18 days out, does good work. Next up flowing injector would be the 211-3024/10R-8502, flows about 10% more.
  4. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    cat remans are iffy new are not much better hit or miss
