cat c13 uses extra oil between oil changes
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gerardo1961, Jul 18, 2012.
  1. gerardo1961
    gerardo1961 Road Train Member
    1,737
    601
    Feb 21, 2010
    Miami
    Hi my question is the last 20 k my engine cat c13 use more extra oil between every oilchange,before my last 280k everytime max 1/4-1/2 gallon extraoil,now the last 2 oilchange everytime extra between 2-3 gallons oil,is this a sign for the future to do a overhaul on my engine now i have 783k ,the engine runs very nice and a have a very good mpg,only i thinking why this happen with the extraoil somebody knows maybe something iam not a mechanic only pay for the work.thanks for you answers
  3. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    older engines get tired and use oil is the sinple answer
    if it isn't on the ground underneath you it isn't a leak
    and you would have to tear down the engine and rebuild it most likely
    to avoid using oil at that mileage
    gerardo1961 Thanks this.
  4. gerardo1961
    1,737
    601
    Feb 21, 2010
    Miami
    No oil leaks nothing on the ground.
  5. Cranky Yankee
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    so the other part of the simple answer is rings
    oil is cheaper then a major rebuild
  6. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    worn piston rings,bad seal in turbo, air compressor could be pumping oil(you would see oil in air tanks) valve stem seals or oil cooler leaking into radiator, but that much oil usage it would be overflowing rad cap.
  7. Grumman
    Grumman Light Load Member
    289
    120
    Nov 7, 2009
    Locust Grove, GA
    As I've been told, the smaller displacement engines typically will not see the same service life as their larger counterparts.
  8. gerardo1961
    1,737
    601
    Feb 21, 2010
    Miami
    2-3 gallons extra every month,is not to expensive,walmart 1 gallon mobil delvac $13
  9. gerardo1961
    1,737
    601
    Feb 21, 2010
    Miami
    next year i like to buy a other truck with very low milage.with a catengine
  10. NYROADIE
    NYROADIE Heavy Load Member
    773
    471
    Jun 24, 2010
    Rochester NY
    I have a Prostar with a Cummins in it and was concerned about oil useage and sometimes low pressure (200,000 mi) I had the oil filter changed (wasn't due for oil change) and believe it or not that took care of the low oil pressure. As it starts getting close to oil change time it will go thru about 1gal @3000mi. Dealer said no problem? They don't consider it excessive til it's useing 1gal EVERY 1,000!!!
    Hows that dealer support?
  11. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    At this point in the story,Homer Simpson says " D'oh".:biggrin_2555:
