CAT C-15 twin turbo oil pressure ??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by GYPSY65, Feb 22, 2015.
  1. GYPSY65
    GYPSY65 Road Train Member
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    I have an 06 CAT C-15 twin turbo with 970k
    I have had next to zero issues with the motor or truck for that matter but it has been well maintained, I replaced both turbos a year ago, didn't need it but I had to change a gasket and already had them off, according to the shops gauge they were right in the middle of don't replace and do replace, so I just did it
    I recently had the rods/main bearings replaced, the damper/balancer replaced, injectors re-sealed?? not sure what that was about but did it along with adj. the valves
    Shop said rod bearings looked like they were new, in other words great shape, the mains however were worn, maybe due to a bad balancer??? I don't know
    Question is, my oil pressure before all this was about 65-68 or so on start up then it would run around 60 plus or minus running down the road warmed up
    Now it is about 60-62ish on start up and heated up running down the road it's more in the low 50's
    here's psi on a hot motor
    idle 650rpm its 30 psi
    1000rpm it's 50 psi
    1300rpm it's 58 psi
    Everything is running great and I only did the work as a precaution to squeeze a few extra miles out of it
    did the psi drop because it may have been running higher before the work due to a small issue that was fixed? or is it a normal reading and that it dropped is just nothing to be concerned about?
    Thanks in advance
  3. skallagrime
    skallagrime Road Train Member
    3,836
    9,879
    Apr 10, 2012
    Indiana
    did you change the oil you are using from say a 15w40 to a 5w40?
    what's the oil change interval youre using?
  4. GYPSY65
    1,956
    5,263
    Nov 16, 2012
    SW FLA
    I don't know what the shop used, I have always ran Delvac
    I ran it about 5000 then changed it with Delvac but no difference, I usually change it every 15k
    It was done about 10k ago, I would think if something was wrong it would have shown up by now, I know the numbers are fine but dropping after bearing replacement is just a concern
    I also idled overnight and that's what my readings were, turned off engine for about an hour, just started it and at 800 rpm the psi was at 58 and the motor temp was still about 150 if that means anything
  5. skallagrime
    3,836
    9,879
    Apr 10, 2012
    Indiana
    only thing i can think of is after having engine torn into might need a slightly advanced oil change (or at least the filter) clogged filter could cause an oil psi drop....
    but im no expert and not really a greasemonkey myself (despite the amount of it i seem to get all over me at least once a week)
  6. TURKER
    TURKER Medium Load Member
    344
    97
    Aug 11, 2009
    Raleigh NC
    I have the same engine 06 cat msx 475Hp my oil pressure when hot stays around 48-52.
  7. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    hmmmm, my 06 mxs holds about 62 at 1300 at 190 degrees , 985,000 miles all original
  8. TURKER
    344
    97
    Aug 11, 2009
    Raleigh NC
    Hey
    Now you made me nerves, I did take oil samples last oil change to Cat dealer , everything checked out OK.I will check the oil again. Last oil change was at speedy I am not sure that they put in Delvac I asked for it?? What oil do you use?
  9. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    Did shop use plastigauge on main bearings? Accidentally bent oiler tubes when checking rods?
