Cat barring/turning tool compatible with Cummins?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Company Wrench, Feb 1, 2025.
  1. Company Wrench
    Company Wrench Bobtail Member
    5
    Feb 1, 2025
    I bought a Cat engine barring tool, it's in the mail. Simple design, socket type with teeth to turn the flywheel for valve adjustments ect... Wondering if this will work on Cummins ISX? I don't see that (Cummins) turning tool online so far.. Thanks!
  3. Iamoverit
    Iamoverit Road Train Member
    1,536
    3,316
    Oct 31, 2023
    Why not try it and let us know if it worked?
  4. dosgatos
    dosgatos Medium Load Member
    547
    1,200
    Sep 18, 2012
    On Cummins use a 3/4 square drive barring cummins.png
    Oxbow, Goodysnap, Bean Jr. and 2 others Thank this.
  5. Company Wrench
    5
    Feb 1, 2025
    Thank you very much for the information and drawing!
    Oxbow and Bean Jr. Thank this.
  6. Dll6
    Dll6 Bobtail Member
    4
    Feb 2, 2022
    Did the CAT tool fit the ISX ?
  7. Dll6
    Dll6 Bobtail Member
    4
    Feb 2, 2022
    If not .. is there a flywheel housing barring/turning tool for the Cummins ISX, NT/NH, N14?
    Google has produced no fruit..
  8. Company Wrench
    5
    Feb 1, 2025
    No, the Cat tool worked great for the Cat 3176, the same tool is used for the majority of the Cat line up. C11, C13, c15 and more. We did have trouble locating the barring tool port. On my 3176 engine it was top right of the flywheel housing behind a transmission filter housing on a Cat 730 articulating dump truck- hard to get to but not impossible- job is done. The Cummins ISX uses a simple 3/4 socket wrench on the front left of the engine. You must remove the small 2 bolt access plate then insert wrench to the cog. Dosgatos was nice enough to post this procedure above on this thread; just scroll up and have a look. You will need to get the marks ABC situated on the harmonic balancer after that. I'm assuming you are setting valve lash?
  9. Dll6
    Dll6 Bobtail Member
    4
    Feb 2, 2022
    Clutch adjustment .. I was hoping to use the flywheel bell housing barring hole that's accessible from under the truck
  10. Company Wrench
    5
    Feb 1, 2025
    Ok. I know that is possible for sure but I personally have not done that- yet. I’ve had mechanics do that on our trucks in the past
  11. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    I have never had to use a barring tool for any clutch adjustment. Just bump it over with the starter. Once you get it close, fine tune with a pry bar thru the inspection hole.
    Pro tip- during any clutch replacement. Put the adjuster at the bottom. The engine is at a natural resting place when it was shut off. One in three shot it stops in front of the opening during service/ adjustment.
    dosgatos, Oxbow, Star Rider and 2 others Thank this.
