Can the cat gurus help me out and explain to me how I can tell if the water pump is getting weak or going out. The problem I'm having is water temp runs hot when rolling up n down small hills but flat land and down hill it runs cool n normal. I also noticed my oil temp is running up on 190-200 also when it never got that high unless on a big hill. Now I got a new Detroit radiator, cac, and ac condenser. I also just changed the thermostats running 190's instead of the 180's I had. Peterbilt told me the pump is fine and psi was 20-23 with a 16lbs cap on but I don't believe them. I still think its the water pump going. I have no leaks or coolant loss.... thanks
cat 6nz water pump
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigstank, Jun 1, 2013.
Not a Cat Guru, but have experienced some water pump failures where the impeller will spin on the shaft. But when this happens you will not be able to pull a load and even have to be careful bobtailing not to overheat it. You did up your operating temperature by 10 degrees when you changed those thermostats. I'm also wondering how many rows you have on your new radiator? And what about that fan clutch, is it slipping?
bigstank Thanks this. -
4 core upgrade and idk on the fan I can't really tell if it is
Nut that holds impeller tight on pump shaft may be loose pull off back cover and plate check for a loose impeller i ran into this with my last truck took off nut cleaned and red loctite fixed it up .
I bought the heavy duty dura one not oem. It might be the 190 stats I'm not used to it running 200 deg in the hills. My fan kicks on at 205 so its on - off all the time. And on big hills I gotta let outta the fuel to keep it from throwing the lights n code for high water temp. It might be the fan hub going out. Its driving me crazy lol like I said on flat the oil n water stay 180 I didn't know if the PDI power makes it run a little warmer. Also hey superhauler, PDI stage one turbo what should be the psi be? One time mines 36 then its 40
SAR Thanks this.
Yeah all 3 were from Detroit radiator. And my PDI set up is all stage one with the manifold, and no I don't know or have a air intake temp. Truck runs fine n pulls awesome just warm that's all. Fuel mileage is up around 5.8-6 @ 70-75mph.. oh and my egt's don't run over 800º
