Cat 3406E More power!!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by EvilTrucker, May 21, 2009.
  1. EvilTrucker
    EvilTrucker Bobtail Member
    8
    california
    Im looking to get more power out of my cat 3406e,
    its at 475hp right now, I took it over to cat yesterday
    to get it turned up to 550hp but they wouldn't do it
    because they said "the transmission would not handle
    the torque" is there anything else i can do to get
    some more power?
  3. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    start reading the older threads on CAT motors posted here.
  4. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    As Mr Haney said... you can spend hours reading here:biggrin_25519:
  5. 7mouths2feed
    7mouths2feed "Family Man"
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    Look for posts made by 550hpW900L. Also there's some pulling truckers here that havce post about big HP
  6. Jas
    Jas Medium Load Member
    An uprate is the best way to increase the horsepower, pull the ECM and take it to a dealer to have it flashed off the truck, if they dont see the truck they cant tell you the trans cant handle the torque. if they ask tell them its off a farm truck or similar which is not registered and therfore cannot be take into the dealership.
    The dealer cannot flash the truck to 550 if the trans isnt rated to the right torque, or if the cooling system is not rated to a high enough horsepower because they can be held liable in court if it fails. If you take the ECM to them off the truck and tell them the trans and cooling system are ok they cant be held liable because they had no chance to inspect the truck and can only go off the info you supply them.
    insertnamehere and EvilTrucker Thank this.
  7. EvilTrucker
    8
    california
    Thanks for the info!! whats involved with taking the ecm off the truck, i dont want to screw anything up!
  8. Mr. Haney
    2,693
    2,040
    Dec 17, 2008
    tools needed
    4mm allen wrench
    1/2" socket
    1/2" wrench
    9/16" socket
    9/16" wrench
    Just disconnect the wiring harnesses from the ECM using the 4mm allen wrench and then unbolt it from the block
  9. Jas
    Mr Haneys on the money, nothin to it, but being a 3406E yours will mostly likely have fuel flowing though the ECM. All you have to do is remove the lines, you'll lose a little bit of fuel, when you reconnect them you will have to bleed fuel system but its not hard, just pump the priming pump while someone cranks the engine and it will start ok. A 5/32 allen key will also do the job.
    BTW should have mention in my other post...that would work with dealers out here in AUS, in the States the dealer may find some other reason to turn you down anyway. If that is the case pm DDS, he may be able to help you out.
  10. The Challenger
    The Challenger Kinghunter
    7,127
    3,367
    Dec 22, 2007
    East Central FL
    what kind of tranny do you have? If your CAT says they couldn't than my guess would a FRO16 something as thats the max that tranny can take.
    KH
  11. 550hpW900L
    550hpW900L Road Train Member
    1,874
    1,090
    Jan 29, 2008
    norcal
    KH to the rescueeeeeeeee!
