Cat 3406e fan staying on
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Highwolf89, Aug 11, 2014.
  1. Highwolf89
    Highwolf89 Light Load Member
    294
    61
    Jul 30, 2013
    I am having a problem with my engine fan staying on constant... I had someone tell me to disconnect the air hose and see if it stops.... When I start it back up and it keeps going... Another person told me to spin the blade with the truck off and see if it spins freely and it doesn't.... Someone told me maybe the fan clutch is bad... But I have a friend who can't spin his blade on a Detroit but his doesn't stay on constant works like it should... Any ideas....
    thanks
    will
  3. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    If your 3406e uses air to turn your fan ON then your fan should spin freely with your engine OFF. Newer trucks use air to release fans, that way fans remain ON when engine is OFF. You need to figure out what type of fan you have on your truck. My truck is 1998 and with engine OFF I can spin my fan.
  4. Highwolf89
    294
    61
    Jul 30, 2013
    Ahh my truck is a 96 kenworth t600 so it is the clutch fan then ?
  5. maggard359
    maggard359 Medium Load Member
    476
    413
    Nov 20, 2013
    Florida
    Could be the fan itself, but more than likely you have a temp sensor reading high or an a/c sensor reading high pressure. Follow air hose from fan back to firewall where you will find the fan solenoid. You can use a test light and see if it's being powered on. That will rule out fan itself if something is sending power to it to supply air to fan. Good luck.
    Luwi67 Thanks this.
  6. beltrans
    441
    101
    Nov 26, 2008
    spokane wa
    I understand that OP already tried disconnecting the air hose going to the fan clutch and it still stays ON.
  7. maggard359
    476
    413
    Nov 20, 2013
    Florida
    There is a normally open solenoid and a normally closed solenoid. Don't know which he has.
  8. Highwolf89
    294
    61
    Jul 30, 2013
    When I put on the manual switch air comes out of the hose going. To fan
  9. Jimmbuds
    Jimmbuds Medium Load Member
    398
    179
    Apr 20, 2009
    Daytona Beach, FL
    Did you just recently wash the engine? My experience in the past when I soak the engine mine would screw up. This is especially true when the engine is cold but I have done it when it was warm as well.
  10. beltrans
    441
    101
    Nov 26, 2008
    spokane wa
    Try tapping lightly on the fan clutch. I remember my friend's 6NZ fan clutch would not release. He removed it to repair and realized that his fan was already spinning freely. So my friend put it back on his truck and the fan has been working fine for couple months now.
  11. Highwolf89
    294
    61
    Jul 30, 2013
    My problem is it stays on all the time .. Could it be rust or something making it stick from keeping it free ?
