cat 3406c water pump
Discussion in 'Trucks [ Eighteen Wheelers ]' started by countryboy23, Jun 15, 2015.
  1. countryboy23
    countryboy23 Bobtail Member
    6
    trumansburg,ny
    Hello everyone,
    I have a 1995 kenworth w900 with a cat 3406c mechanical motor.had an inframe done a little over 200k miles ago. I just recently bought the truck and noticed that I had coolant in my oil. So I started to investigate what the problem is. As I have been reading forums and asking my buddy who works as a heavy truck mechanic to see what procedures I can do to determine what could be the problem I happened to notice that my weep hole on my water pump had a rubber plug in it. Would this cause a seal to blow out and leak in to the front engine cover? Here is a picture of what I found.
  3. mtoo
    mtoo Road Train Member
    1,928
    4,427
    Jan 15, 2011
    Retired on bended knee
    I know it can be several things but. For me and cats, it has always been oil in radiator = oil cooler. coolant in oil = liner. bubbles in radiator = head gasket, I have no idea what a plug in the weep hole would do.
    Someone will tell us.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    If some idiot went to that extent by putting a plug in the weep hole to stop coolant from coming out. Then yes that would be your problem .
    Put a new pump on it asap
    That weep hole is there so you don't get coolant in your oil when your water pump packs it in.
    Geez I thought I've seen it all but I guess not
    countryboy23 Thanks this.
  5. countryboy23
    6
    trumansburg,ny
    That's what I wanted to hear.
    Thank you .
  6. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    That is sop for idiots. I know a man who did just that. He had a leaky water pump so he sooo wisely plugged the weep hole which caused the coolant to run straight down into the oil pan. It cost him a rebuild. I suggest you change the water pump. If you don't know this heed a word to the wise - DO NOT DROP the water pump even when boxed as you may well end up putting another one on. I would also change the oil and filters. If the engine does not have a water filter, I would put one on.
  7. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
  8. wore out
    wore out Numbered Classic
    15,319
    184,961
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Do the right thing before you spend a dime. Pull the pan and pressure the radiator it needs new oil anyway. What you wanna hear could be far from the problem
    bigguns, countryboy23 and rollin coal Thank this.
