CAT 3406c question
Discussion in 'Trucks [ Eighteen Wheelers ]' started by NadeauTrucking, Feb 11, 2012.
  1. NadeauTrucking
    NadeauTrucking Light Load Member
    85
    45
    Jul 24, 2011
    Bristol, CT
    How do i know if my 3406c in my 97 LTL 9000 is a PEEC motor or not. There is a throttle linkage from the pedal to the injector pump. The only reason i ask is because i drive a similar 9000 that is a 95 with a 3406c and they absolutely sound nothing alike. My 97 also has a engine shutdown overide switch which leads me to believe that it must have some electronics while the 95 does not have that switch.
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    If it has mechanical throttle then its not a Peec motor peec will have a potenteometer on the throttle pedal
    NadeauTrucking Thanks this.
  4. NadeauTrucking
    85
    45
    Jul 24, 2011
    Bristol, CT
    Then what would the difference be between the 95 and the 97 and the shutdown override switch. i wish i could remember the serial number on my engine. the 95 just seems to sound more mechanical during idle as where the 97 sounds like its more electronically controlled. the 95 has a low rough choppy idle whereas the 97 has a nice smooth high idle.
  5. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    The 97 is Probly an e model the overtide switch is for the shutdown system that's why u have to hold the override switch until you have oil pressure
  6. NadeauTrucking
    85
    45
    Jul 24, 2011
    Bristol, CT
    what do you mean by e model? i havent been around the commercial diesel engine world for very long so bear with me. i do learn fairly quick though and i do appreciate all info. im pretty sure by e model you dont mean 3406e so a little clarification would be very helpful.
  7. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    He said it has linkage on it, not seen to many E models with a manual pump.
    My best guess is that the truck has an engine protection system on it that kills the power to the solenoid if oil pressure drops or water temp gets to high. The override is so you can get it off the road if something happens and it shuts down.
    Pictures of the engine or a serial number would identify the engine for sure.
  8. truckmechanic
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    I said the 97 was most likely a 3406e I might b. Wrong but I don't think you could get a 3406 a b or c on 97
    pretty sure the 3406e was the only one don't take my word for it he said the 95 had throttle linkage which means its am a or b I thought a c was a orb motor
  9. NadeauTrucking
    85
    45
    Jul 24, 2011
    Bristol, CT
    no, they both have throttle linkages. i will be back on tomorrow with a serial number for my engine. i have the vin handy but i doubt that would help. i appreciate all of the responses and i hope im not too much of a pain in the ###. i just like to be knowledgeable of my equipment.
  10. catmech2
    catmech2 Bobtail Member
    Feb 11, 2012
    The mid 90's offered the 3406C mechanical (s/n prefix 3ZJ,8PN), 3406C PEEC (s/n 8TC, 4CK, 5KJ) and then the 3406E model with an early prefix of 5EK. Truckmechanic was correct in that the mechanical engine will have a metal throttle linkage going to the governor at the rear, side of the pump. The fuel system will have six metal fuel lines that connect up to the cylinder head. The PEEC is part mechanical (fuel system) and part electronic (governor). The PEEC will have three wires coming out of a circular looking BTM (electric throttle) on the side, rear of the fuel system. The wires will go to a connector (along with two other connectors) that are held in a bracket on the top or very rear of the fuel system "governor". Right behind it is a large rectanguler box with wires going to it, which is the ECM. The 3406E will not have the fuel system at all, only the ECM toward the rear of the engine.
  11. NadeauTrucking
    85
    45
    Jul 24, 2011
    Bristol, CT
    I do know for sure that my s/n starts with 8PN, but i will have the complete number and pics up soon. i want to know as much as i can about this truck so i can properly enhance/maintain it.
