cat 3406 pcta
Discussion in 'Trucks [ Eighteen Wheelers ]' started by craggy1982, Dec 23, 2013.
  1. craggy1982
    craggy1982 Light Load Member
    205
    386
    Apr 21, 2012
    KY
    cat 3406 pcta. can anybody tell me the difference is between this engine and the 3406b other than that the 3406 pcta is a pre-combustion turbocharged aftercooled and 3406bs were DITA. im looking to find out how reliable the 3406 PCTA is.
  3. wore out
    wore out Numbered Classic
    15,319
    184,958
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The pump and timing advance is totally different. The B pump bolts right to the front structure with the timing advance inside a cone shaped cover on the front of the timing cover. The PCTA pump is driven by a shaft and is mounted farther back on the engine. Timing control isn't near as good and as with any glow plug engine the pre cups where the glow plugs are, are bad to crack. They are were good engines and could be pretty stout, but loved fuel, Usually about 4 to 4.5 is tops. Most of the pre cups were changed to DITA years ago when they were over hauled you could exchange the head for a DITA head with no core charge. The last version of the 3406A were direct injection from factory.
    snowman_w900 and Cetane+ Thank this.
  4. craggy1982
    205
    386
    Apr 21, 2012
    KY
    does fuel mileage increase when converted to a DITA? I have 3 trucks Im looking at. the 3406 PCTA has the lowest mileage on motor and cheapest to buy but I am leaning towards a truck with the 3406b. the 3406b has twice the mileage but is an 87 model vs being a 75 model cat.
  5. wore out
    15,319
    184,958
    Jun 5, 2013
    No the millage really doesn't. The B is alot better engine all around and finding some one who really knows an A is tough. Course the B is getting that way too.
    Cetane+ Thanks this.
  6. craggy1982
    205
    386
    Apr 21, 2012
    KY
    yeah at least with the b's there are still a lot of them running around here in my area along with the cummins mechanicals. they still a pretty popular motor in the ohio Kentucky Indiana area for independents
  7. wore out
    15,319
    184,958
    Jun 5, 2013
    They are not as plentiful here in NE Arkansas but they are around. By far they are my engine of choice. We have a 7fb 350hp in a w900b ken worth pulling a 28 ft dump out of a quarry that avg 6.8 a gallon with 80k gross. 35 mile one way haul we are tickled with.
    Oxbow Thanks this.
  8. wore out
    15,319
    184,958
    Jun 5, 2013
    Don't get me wrong the A is a fine engine just hard on fuel
    Oxbow Thanks this.
  9. FLCGuy
    FLCGuy Bobtail Member
    It NEEDS air. Try putting a late b/early C turbo on it..my 86 flc went from 4 to 5.8 mpg with no other mods..15 sp. .81OD, 3.7 rears on short 24.5's..1650@60mph
  10. W900AOwner
    W900AOwner Heavy Load Member
    714
    1,284
    Jul 2, 2014
    I'm reaching here myself, looking at older posts about 3406A PCTA's. I am running a 1978 3406A in my 78 W900A model. I am not looking for miracles here, but I'm really wanting to try and get a little more power out of this engine during the time I plan on running it in this truck. The end goal is to find a B or C ultimately, and do a swap out. But I have to wait a bit; so in the meantime I'd like to get some info if anybody has had the same similar experience as this with an A.
    Mine supposedly is a factory 375 HP based on the VIN of the truck. Again, I don't expect a major transformation in power based on the engine's specs, but there's gotta be "something" I can do to temporarily get this thing to pull slightly better than it does. Right now I'm really making her work hard, and averaging about 4.8 mpg. It's a 15 double over with 4:33 rears. It goes OK on the flats but hills are not our friend now. It's just kind of numb, my B seemed to make power when you got into a hill as where this A just falls on it's nose.
    Can somebody tell me what I can do to get a little more out of her? I'm thinking a bigger turbo to get more air, and a bit more fuel to spin it...I drive it by the pyrometer anyways, so I don't plan on cooking it. I ran a 1986 B model for years with no charge air cooler, just watched the exhaust temperature closely.
    If anyone has any good ol' custom tricks that I can use to get another 50/60 HP or so more I'd be tickled. What turbo should I be looking for? One off a later B, or thereabouts? A part number would be nice too...
    Thanks in advance.
  11. Oxbow
    Oxbow Road Train Member
    12,448
    127,832
    Nov 24, 2015
    Let me add to what @wore out said, the first B models did not have ATAAC (air to air after cooling), but had water jacket after cooling (JWAC). The increase in horsepower from 400 to 425 came with ATAAC. Correct me if I'm wrong wore out.
    snowman_w900, W900AOwner and wore out Thank this.
