CAT 1693 to Detroit 6v92?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Isxrookie, Sep 29, 2019.
  1. Isxrookie
    Isxrookie Light Load Member
    82
    45
    Jan 24, 2011
    New Orleans, la
    Just purchased a 1973 White Freightliner and I'm looking swap its engine. How difficult would this be or would it be fairly easy? Im thinking I probably would need motor mounts? What do you guys think?
  3. Isxrookie
    82
    45
    Jan 24, 2011
    New Orleans, la
    Lets hear your thoughts....
    Im a sponge at the moment
    Intothesunset and Oxbow Thank this.
  4. AModelCat
    154,534
    If you were closer to Canada I'd buy the 1693 if it ran.
    pushbroom and Oxbow Thank this.
  5. Isxrookie
    82
    45
    Jan 24, 2011
    New Orleans, la
    yup its running too, I just don't care for it. I already have a 3406e that im not fond of
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    It was the Cats Meow in the day. I would not put a 6V in place of one. Maybe a 8V 92 or a 12v 71 if it had a hole in the block.
    Have you ever done an engine brand swap. Unless you have a same brand donner truck you normally run into more problems than you could ever imagine.
    Every problem is more time and money.
    c15, Oxbow and AModelCat Thank this.
  7. Isxrookie
    82
    45
    Jan 24, 2011
    New Orleans, la
    what kind of problems do you think? I was thinking motor mounts
  8. AModelCat
    154,534
    Engine mounts, rad connections, heater hoses, electrical would need to be modified (not that there'd be much more besides basic sensors), exhaust routing, intake piping, possibly some alterations to the doghouse (assuming your profile pic is the truck). May need to modify radiator/fan shroud as well. Depending how everything mounts up the transmission location may change, resulting in modifications to driveline, driveshaft angles, shift linkage and clutch linkages. May even have to change the oil pan sump configuration depending on how everything fits.
    Oxbow and BoxCarKidd Thank this.
  9. AModelCat
    154,534
    Definitely don't want to discourage you but it'll be a big project and take some time to do. I'm all for doing the wild and crazy stuff lol.
  10. BoxCarKidd
    4,418
    6,432
    Aug 26, 2014
    And the front crossmember for the front motor mount may be different.
  11. BoxCarKidd
    4,418
    6,432
    Aug 26, 2014
    But why do all that for a 6V 92. 12V 92 boat motor swap maybe. That would be cool!
