Cat 10r7172....do they exist anymore?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by snowman_w900, Feb 6, 2014.
  1. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    getting my ducks in a row to do another overhaul on an acert.I have called several places to try to get a hold of a set, and these things are getting hard to find. Midwest said they haven't had any for a while, Kenworth, peterbilt both say its not in there system and cant get it. the CAT house says those are severly back ordered and around 650 a pack and possibly a month or 2 to get a hold of. I'm now reconsidering my Acert plan. Looks like an E model is gonna be the more economical way to get it done now. what y'all think?
  3. Eustace
    Eustace Bobtail Member
    47
    12
    Jan 28, 2014
    Called about a week ago and all they could find was 3 packs in FL.....so if you want to overhaul 1/2 a motor your in luck. Been just cutting the 18:1's. Only other option seems to be IPD.
    snowman_w900 Thanks this.
  4. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    hate to be nosey, but what are you guys taking off? just wondered how close to 16 you gu
    ys are getting to
  5. ROBSREDFORD
    ROBSREDFORD Light Load Member
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    The readily available 248-5516 piston is 17:1. Ipd carries it also. Milling .080 off a 17:1 makes it about 16:2 If math correct. I wouldn't worry with milling
  6. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    this may be a stupid queston, but if anyone is using the 248-5516 IPD pistons, what rings are you putting in with it? cat or IPD? just curious.
  7. ROBSREDFORD
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    Ipd has 16:1 pistons now. No need to cut.
  8. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    Thanks for that info. I hadn't investigated that far into it. hate to ask, but is there a way to get the part number for the piston and also do we have change the piston oiler nozzles to accommodate? I appreciate all the info sir.
  9. ROBSREDFORD
    266
    139
    Sep 2, 2008
    MIDLAND, NC
    Piston is 3466615. Last time I checked oilers crossed to same base number but check CAT house to be sure.
  10. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    From what I have came up with, is the 3466616 16:1 piston uses the 2791152 oil jet, the 2485516 17:1 uses the 2764637 oil jet. one thing I haven't checked yet is if one of those numbers superseded the other as far as cross reference.
