castrol 10w30 semi synthetic instread 15w40 for high milage C15 475hp
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bob1974, Dec 23, 2022.
  1. bob1974
    bob1974 Bobtail Member
    first time i am using 10w30 semi syntheitic in c15 is it safe to use it using semisynthetic for C15 475hp ??
    since i changed no issue on ideling anymore b4 it shakes for half minues when i start after turning off for 15 mins Please any help
  3. Lazer
    Lazer Road Train Member
    1,727
    2,713
    Jan 22, 2017
    We use ‘synthetic blend’ 15w-40 in everything we have, CAT, Cummins, Detroit’s, MB’s. All ‘unbranded’ suppliers, never had an engine problem that could be traced back to the oil.
    Diesel Dave Thanks this.
  4. bob1974
    what is diffrent between semisynthetic and blend synthetic?
  5. RubyEagle
    RubyEagle Medium Load Member
    632
    788
    Apr 17, 2010
    The Delo 10-30 bottle claims better protection than a 15-40. I had good oil samples with it in a DDEC 3 Series 60. It will flow faster and you gain fuel milage with it most likely. Flows faster during cold starts good for winter.
    brysol01 Thanks this.
  6. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Local cat house only has 10W30 in bulk at their shop. They advise to use that grade year round.
    Ive used full synthetic for ever in a E model and then a C15. The c15 has 630K and like 22k hours on it. You might develop some oil leaks but that’s it ……
    As far as the difference between a blend and a semi . I don’t think there is one…… all semi synthetic oils are part Dino and part synthetic I believe ?
    we had some oil experts on here maybe someone will chime in…
    Oxbow Thanks this.
  7. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    Is bob the oil guy still around
    Oxbow and Diesel Dave Thank this.
  8. bob1974
    yes thats is why for this winter i am using 10w30 semi synthetic easy start in winter
    but still looking for advice for high mileage truck which wil be good any cat oil expert please advice
  9. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    15W40. Lighter grade of oil for newer engines to reduced internal drag and increase mileage. Not a fan of thinner oils and extended intervals.
    AModelCat and Oxbow Thank this.
