Cascadia Turn Signal Problem
Discussion in 'Freightliner Forum' started by Shadetree Trkr, Oct 19, 2013.
  1. Shadetree Trkr
    Shadetree Trkr Bobtail Member
    15
    5
    Sep 7, 2012
    I have a '13 Cascadia. The left turn signal flashes quickly. The condition also exist with the 4 ways. And intermittently the trailer left turn signal will flash with I'm hooked up. I'm guessing there's something wrong with a relay in the SAM. Any ideas??
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    ck. and find bad bulb on L side,you can tap on them with turn sig. on til. you find the bad one.
  4. Shadetree Trkr
    15
    5
    Sep 7, 2012
    Found the problem. Turned out to be a relay was sticking. Turn it out and swapped it with the right side relay. If it sticks again, I'll just go buy a new one.:biggrin_25512:
    kee1227 Thanks this.
  5. Freightliner-2013
    Freightliner-2013 Bobtail Member
    10
    Hi bro I read your post, I have the same problem could you please tell me where is the relay located I have freightliner cascadia 2013
  6. Animosus
    Animosus Heavy Load Member
    708
    2,774
    Dec 7, 2015
    SE Wyoming
    The relays for the turn signals are located in your SAM_CAB behind the glove box.
    Freightliner-2013 Thanks this.
  7. Freightliner-2013
    10
    Thanks , I did open it I didn't found relays turn signals on the identification paper, sorry bro , could you please tell me what name I should look for .
  8. Mindsoul
    Mindsoul Bobtail Member
    39
    17
    Feb 17, 2012
    Chicago Il
    Driver side, in the engine bay fuse box near steering column.
  9. Coco28
    Coco28 Bobtail Member
    Freightliner cascadia 2011,
    I have problems with the stop light and right signal is not working properly
  10. Coco28
    Someone who can help me with the problem,please.
  11. leebiker06
    leebiker06 Bobtail Member
    6
    Hi can someone please tell me what to do I just buy a 2011 Freightliner cascadia I drive it all the way from Texas to pa with no problem now my headlights and my turn signals and my bunk lights are not working can someone help me out? Also where do I find the turn signals relay thank you
