Cascadia transmission issue
Discussion in 'Freightliner Forum' started by cernim, Jul 14, 2019.
  1. cernim
    cernim Bobtail Member
    18
    11
    Apr 15, 2019
    Woodstock, ON, Canada
    Hey guys I got 2014 freightliner Cascadia DT 12 transmission… If the truck sits for 36 hours plus I cannot put into gear right away… I move the gear selector to drive or reverse they just beeps at me and doesn’t do anything… Then it either takes a while to warm up and then it goes into gear or sometimes when I restart the engine it goes into gear… Any ideas?
  3. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    live with it.
  4. Freddy2times
    Freddy2times Light Load Member
    64
    31
    Feb 12, 2019
    dt 12 is an automated transmission. changes gears pneumatically. if system air pressure isnt high enough would explain why it wont shift at first but after a while it does. check system pressure next time it happens.
  5. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    Air pressure low warning
    Transmission may not shift.
    Doesn't dash show that?
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Drain your air tanks daily .. it really does help with air problems .
    Dave_in_AZ Thanks this.
  7. D.Tibbitt
    140,845
    Mine tells me that transmission air is low and shows a gear symbol on the screen. These auto trannys are junk . when it gets cold outside mine wont shift into 8th gear first thing in the morning , it takes 3 tries for it to finally get it in . all kinds of quirks with these things
  8. Intothesunset
    2,289
    4,880
    Apr 15, 2019
    truck
    Yuppers!!^^^^^^
    D.Tibbitt Thanks this.
  9. Navster
    Navster Bobtail Member
    5
    Nov 13, 2018
    Hello. My DT12 Trans has the same exact issue. Can you please tell me what was the diagnosis and hows it going now ?? Thx
  10. cernim
    18
    11
    Apr 15, 2019
    Since the weather got warmer no more issue
  11. cernim
    18
    11
    Apr 15, 2019
    Nope
