cascadia speed sensor?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigdad7, Apr 28, 2014.
  1. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    Symptons reported by driver cruise will not hold speed surges speedo is going nuts and governor disabled ....speed sensor or demon infestation
    I did ask my driver to do us a favor pleese forget to set the brakes and point it toward a cliff
    Is 10 crapscadia with dd15
  3. Toomanybikes
    Toomanybikes Road Train Member
    2,360
    3,120
    Apr 8, 2009
    Don't know as the truck is not in front of me but I can tell you this: Crapcadia's have had a lot of speed sensor problems. A lot. They also have a poor cruise control that often looses speed and shuts off on its own.
    If you have a qualcom system on the truck swap over sensors between qualcom and truck. They are often the same sensor.
  4. bigdad7
    1,837
    1,364
    Jun 6, 2010
    ks
    Nope no qc ....getting it to a mechanic that i know can diag. It properly but it won,t b there till mon just wondering how much of a hit this is gonna b
  5. jameslawton
    jameslawton Light Load Member
    257
    65
    May 1, 2013
    Tulsa OK
    I would guess the nut on the tranny yoke is loose
  6. bigdad7
    1,837
    1,364
    Jun 6, 2010
    ks
    I was happier thinking it was a sensor
  7. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Does it have any warning lights or codes in the dash display when this happens? Does it have an OnGuard system?
  8. bigdad7
    1,837
    1,364
    Jun 6, 2010
    ks
    Negative on lightss and no on guard either
