Cascadia DD13 Water in Fuel Indicator
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by tallmon, Oct 16, 2018.
  1. tallmon
    tallmon Medium Load Member
    657
    319
    Oct 22, 2014
    I have a 2012 Cascadia with Detroit DD13.
    Getting these 3 codes:
    SPN 97 FMI 3 water in fuel voltage short?
    SPN 97 FMI 15 and SPN 97 FMI 16, water in fuel
    I can't find diags for the 97/3 code. It was the FIRST code that came up. Shortly after that one came then the other two came.
  3. JohnC123
    JohnC123 Light Load Member
    135
    66
    Jan 25, 2018
    I work a short fleet of 2012 Pete's, replaced at least 5 WIF sensors within the last 3 months after having the yard diesel tank (leased) professionally tested for water intrusion, new sensor cheap compared to downtime testing, fixed every time.
    RAFAEL1975 Thanks this.
  4. OilBoomDreamer
    OilBoomDreamer Light Load Member
    73
    35
    Oct 18, 2018
    Wish I can help. I have no idea what either of you are chatting about.
  5. tallmon
    657
    319
    Oct 22, 2014
    I believe you are correct, we just had a second one with the exact same symptoms. Replaced the WIF sensor under advice of a road side mechanic and she's all good now.
  6. Aris
    Aris Bobtail Member
    Hi could you please tell me where is exactly located WIF because i got thesame cod today for 2015 dd13.
    Thank you
  7. tallmon
    657
    319
    Oct 22, 2014
    Driver side. Fuel filter housing. (NOT Water Fuel Separator). This is ON THE BLOCK on the driver side.
    When the engine is on you will see a green LED lit up that says DRAIN or OK. THAT is the sensor. Go get one, easy to replace.
    See attached file for ALL DD13/DD15/DD16 sensor locations aka The Sensor Bible.
  8. Aris
    Aris Bobtail Member
    Thank you, i will try tomorrow and let you know the results.
  9. tallmon
    657
    319
    Oct 22, 2014
    Do it quickly, because fuel will be coming out and you don't want too much to come because you might lose prime. If that happens you'll have hand pump it. The pump is right next to the large black filter.
  10. Ladda
    Ladda Bobtail Member
    I have same problem
  11. Ladda
    Any body can help
