Cascadia battery saver problem
Discussion in 'Freightliner Forum' started by shawnl, Jan 30, 2013.
  1. shawnl
    shawnl Bobtail Member
    7
    Jan 30, 2013
    Anyone had the same problem? Dd15 2009 model saver kicks on after 1-2 mins. new batteries all wiring has been checked
  3. Rgxtrucking
    Rgxtrucking Bobtail Member
    11
    5
    Dec 21, 2012
    My 2012 cuts off some of the 12volt plugs and interior lights after a few minutes unless I have the TriPak switch on. Sometimes the TriPak starts as soon as the key is turned off. I have to turn it off when pull in to fuel or it will start up while I'm fueling. Even with the lights and everything else off.
  4. shawnl
    7
    Jan 30, 2013
    tripak switch? do you mean the one on the floor? because the new models dont have the same as the older ones. This one is a 2008 actualy
  5. WRIGHTRACING
    WRIGHTRACING Heavy Load Member
    882
    251
    Jan 3, 2011
    Iuka MS/Muscle Shoals AL
    No he's talking about the APU. You're thinking about the main power switch. My battery minder goes off after about 20 mins of sitting with interior lights on. After about another 5 it kills the lights and cig lighters. Then I can kick the APU on and everything comes back on.
  6. shawnl
    7
    Jan 30, 2013
    where is this switch located. This is mainly a volvo garage were having a hard time with this
  7. WRIGHTRACING
    882
    251
    Jan 3, 2011
    The main power switch is in the floor between the driver seat and door, but that only turns the power off and on to the entire truck. An APU is an auxiliary power unit. Its a generator that runs the heat and air, and charges the batteries when the truck engine isn't running.
  8. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    I had the same problem after my batteries were replaced last summer - the power saver cuts in and turns off the lights much sooner since the batteries were replaced. There's nothing wrong with the electrical system per Freightliner. IDK, perhaps there's an adjustment for this - you might ask Freightliner. On the APU side, my TriPak wasn't turning on soon enough so the batteries were running down quite a bit over night. There is an adjustment in the TriPak controller box to adjust the turn-on point, and this should be looked at every time you change batteries since the cell voltages will be different.
  9. shawnl
    7
    Jan 30, 2013
    Found the problem. The altenator had been replaced and they forgot to put a jumper wire.
    GrapeApe Thanks this.
  10. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Good to know. I'll have to make a note of that, we have a few Cascadias.
  11. jbee
    jbee Medium Load Member
    664
    619
    Jun 3, 2011
    NC
    So, I now have a Cascadia with a similar problem except it has NO APU on it. Took my home time (3 days) and the truck starts up, but the 12v DC outlets no longer have any power going to them.
    Should I:
    -Find the fuze box because those fuses are blown or need to be reset? (My Prostar had "Circuit Breaker" type fuses, not sure if this one does as well or not)
    -Turn off the Master Power Switch for a while and see if everything resets after?
    -Run the truck for a half hour to get enough juice in the batteries and everything will then reset?
    Thanks in advance for any help on this you can provide. .
