Cascadia 2016 reliability…
Discussion in 'Ask An Owner Operator' started by Truckinson, Jun 27, 2023.
  1. Truckinson
    Truckinson Bobtail Member
    7
    Jun 27, 2023
    Hey to all,
    Looking into purchasing a used Cascadia 2016 with 675k miles on it… DD15 with 505 hours…
    Asking the owners and mechanics and the other ones that know the truck…
    How reliable are they? Any common problems? Overall good and bad about that yr and model ….
    Thanks in advance for your answers!
    D.Tibbitt Thanks this.
  3. LoneRanger
    LoneRanger Road Train Member
    3,661
    9,445
    Jun 3, 2018
    It’s due for a new one box that’s for sure and maybe another 100-200k miles left on that engine.
  4. Arctic_fox
    3,859
    19,392
    Sep 16, 2016
    It would be cheaper in the short mid and long term to find some old iron and throw an engine rebuild at it right off the bat. DD series engines usually need a rebuild in the 600-800 range depending on how they got used. though occasionally they make it to 1 mil. One boxes usually start showing signs of wear around the 500-600K mark if properly maintained and will need maintaince at a minimum and likely a full on replace. Your looking at 10-30K for the emissions system right off the bat depending on how borked it is. And likely a lot more. You are looking at least 30-50K for a rebuild within a year, two tops. You could go as much as 70K if the block is pooched for some reason and you need an entire engine. So figure 40-100K in repairs more or less off the lot. And thats assuneing the transmission and diffs are solid and dont also need rebuilds and ignoreing anything else. Add on the im guessing 50-60K they are asking just to BUY it and you would be better off getting a new rig. Even if the rig is only 30 or 40 its still a bad buy.
    Meanwhile you can pick up an older non peterbilt rig with a 80s-00s era engine and transmission in need of a rebuild for around 20k-40K and have a solid runner by dumping 40k in for a rebuild on the engine. 10k on a transmission rebuild and another 10k for diffs. Maybe 10k more for going over everything else. Call it 90-100K all in for a rock solid rig that will last for a decade at least if maintained correctly.
  5. D.Tibbitt
    140,665
    me personally i would not touch an emissions engine with 700k on the clock unless its been rebuilt and aftertreatment has been gone thru or hit a big pothole somewhere and all that stuff fell off.. if the truck has good bones you could possibly make it work, but need to have money in the bank not only for engine rebuild but aftertreatment as well..id be real hesitant to purchase a truck like this.
  6. Rideandrepair
    17,198
    55,776
    Aug 8, 2015
    All the repairs seem to start around 700-800k. Buying something with almost 700k, it better be priced cheap, or have some major repairs already done. It’s going to need plenty. Just about everything imaginable within a few years. Even hoping to get lucky, running a couple years without major problems is a big gamble. It will probably cost more than a 3 year newer Truck at 40% higher price to begin with. Better to be selling at 675k than buying. It may seem like a good deal. In 2 years there’s a good chance it’ll be just about worthless after spending plenty on repairs.
  7. MrReactor
    MrReactor Light Load Member
    206
    140
    Sep 4, 2006
    Chicago
    Run about 18 of em around same mileage, delete the DEF $2500 and you'll be fine for a few years.
    Worst thing about those trucks is the sensors, every winter the trucks start acting up and mechanics can't figure it out
    77fib77, D.Tibbitt and Truckinson Thank this.
  8. Condi
    Condi Light Load Member
    121
    128
    Sep 9, 2012
    All above is true. Do not buy
  9. abyliks
    abyliks Road Train Member
    3,742
    8,691
    May 2, 2010
    ludlow MA
    until you get nailed somewhere …
  10. Cdemars316
    Cdemars316 Medium Load Member
    609
    3,058
    Nov 10, 2018
    Where are you getting nailed, the only place that gives a f is California if your deleted don't go to California same rules I use on my 2004. Regular dot doesn't give one f about emissions systems on trucks, it is not part of there inspection and they don't look and don't care. The only people that care are carb, and that is only in California
    MrReactor and D.Tibbitt Thank this.
  11. abyliks
    3,742
    8,691
    May 2, 2010
    ludlow MA
    I have the ability to keep an old truck running, so emissions is not something I worry about, which are federal law not state, and there are more and more that are checking, and if you do break down on the road, a majority of reputable shops will not change a light bulb on a deleted truck because they also face fines
    Siinman, Concorde and D.Tibbitt Thank this.
