I know this has been brought up before but I couldn’t find a solid answer.
I load/unload my flatbed trailer with a piggyback forklift. It is a bit of a pita to fuel the forklift at the pumps, especially when it’s mounted on the trailer. The filler neck is high up and it’s on the wrong side, and it only takes a few gallons so it seems like it takes me longer to climb onto the trailer and put the nozzle in there than it takes to actually fill the #### thing.
So I was thinking I’d get a 5 gallon diesel can to carry on the truck and then I could just top the forklift off anywhere. Can I use a small ratchet strap to secure the can to my catwalk or maybe even the deck of the trailer? I also have a couple tool boxes on the trailer I could stow it in, but no good way to secure it in there so it could potentially tip over.
Any thoughts on a safe legal way to do this?
Carrying a diesel jerrycan on the truck
Discussion in 'Experienced Truckers' Advice' started by Kyle G., Feb 8, 2020.
Start here: What Are Materials Of Trade | PHMSA
brian991219, D.Tibbitt and Kyle G. Thank this. -
Cut a couple 4x4 that fit snug against the jerrycan inside ur trailer box . Put can at one end and 4x4 running from can to end of trailer box. Maybe stack 2 tall. Or could maybe cut one to length so it fits in deep , parralell to can then another longways to push against it. . I see reefer drivers with one on their catwalk. Not sure how legal it is. Think its better off being in side box away from the eyes of the dot
Kyle G. Thanks this. -
As far as i can tell, it is legal but must be in a special type of DOT-approved can, which I am guessing your average plastic menards lawn mower type can is not DOT approved.
Regardless, I would probably be better off stowing it in the box, so yeah I think I will put my non-carpentry skills to the test and see what kind of blocking I can come up with. As Homer Simpson once said, “It’s not illegal if I don’t see it.”Rideandrepair and D.Tibbitt Thank this. -
Worst case, just get a can and use it to fill up at the pump and leave it empty
86scotty, Rideandrepair, akaDug and 3 others Thank this. -
Is lugging a 45 pound can a fuel really easier then climbing up on the lift to fuel? I used to back up to the fuel tank at the yard and fuel there or I would run over and fuel when I had the lift off to load myself at the yard.
Rideandrepair and Kyle G. Thank this. -
Carry an empty Jerry can and a siphon hose. When needed, siphon off 5 gallons from the truck tank to fill the forklift.
Rideandrepair, tscottme, Kyle G. and 1 other person Thank this. -
If you fill the fork truck you can use refeer fuel (untaxed) as it's not an on road vehicle.Rideandrepair, Kyle G. and SteveScott Thank this. -
I keep a gallon in a plastic oil jug. Not really an approved container, but never had a problem. Never builds up pressure, like gasoline. A couple on hand, refilling when fueling, just an idea.
It’s not really that big a deal, it was just an idea I had. Just don’t get mad at me if you get stuck behind me in the fuel line and you have to wait for me to fuel my forklift lol.kemosabi49 and Rideandrepair Thank this.
