Carrier 7500 X4 Heat Mode Question
Discussion in 'Refrigerated Trucking Forum' started by STexan, Jan 20, 2019.
  1. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Any reefer mechanics here? I have a Carrier 7500 X4. Load requires 55 F set point. Outside temperature has been around -5 to +5 F all day. Product is stable as it’s been loaded for 48 hours now and was warehoused and loaded at 55-60
    Just seems the unit is really struggling trying to maintain. I was on cycle. Now parked for the night (forecast low of 0 F) I switched to continuous to see how it would react. It’s still bouncing around between heat and cool and high and low speed and I’m not sure which mode is more annoying.
    Are there limits to what it can do with a set point of 55 and with temps in the 0F or colder outside? How should the unit behave differently between the 2 modes? Bills do not require continuous mode but I’m wondering what would be the easiest on the system long term in these really cold temps?m
    It did fine in cycle the first day where temps were around 30-33 F
    I assume they operate similar to a home heat pump system? Don’t heat pumps have limits to what you can expect from them?
    I’m glad it’s not forecast to get any colder than presently until it unloads.
  3. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Turns out there must have been some sort of issue with the unit. It finally stopped heating, shut off, I called and they told me to put it in the heated shop. It immediately warmed back up. Waiting on one of our mechanics to come out and make a determination what might have happened.
    KB3MMX Thanks this.
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Mine does the same thing.. I just had a do not freeze load last week, put it on 60 cycle, it fires up at 55 and actually box temp drops to 50-52 before rising again. I figure it can't actually heat until the coolant is 30+ higher than set point. If it works the same way the truck heat works anyway. The air coming out of the vents is always 30-50° less coolant gauge temp. Because it's much colder where you are now probably experiencing same thing. The constant heat/cool it's trying to put it exactly at set point. I don't think anything is wrong with that reefer.
  5. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Something is wrong because it shut down at 45 degrees with a heat system failure (had been running continuous for at least 3 hours). Turned it off/on and it came back up and running but the box temp was still falling and last I checked before backing into heated shop, it was 40 and still falling. So the problem wasn’t about the coolant temp. But as soon as it went inside a warm area, it instantly began raising the box temperature.
    KB3MMX and gokiddogo Thank this.
  6. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    There is a temperature recorder in this load (single product candy, kind of like mini Reese’s PB cups with a darker chocolate).
    Maybe the temp was below 50 (55 set point) for 2-3 hours? Maybe it recorded 40 degrees for 20-30 minutes?
    Going to be interesting to see if Trader Joe’s rejects the load.
    KB3MMX Thanks this.
  7. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    I've never hauled for trader Joe's... but that shouldn't ruin chocolate bars. Good luck
  8. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    I agree it won’t ruin the product. I think it would take a light freeze to discolor them and make a noticeable change, but quality control is quality control. We’re talking about 30 pallets so there is a lot of product “on the outside”
    They’re kinda like quarter sized ‘Reese’s Peanut Butter Cups’ in a “muffin” paper cup, then wrapped with a decorative Trader Joe’s foil. I know because I was given about 4 lbs of them (unwrapped seconds) as a driver appreciation gift.
    KB3MMX Thanks this.
  9. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    I miss those customers lol
    Used to do some work for Cadbury now and then. They'd always fill my pockets with chocolate eggs etc. Now I do frozen mostly, no freebies anymore.
    KB3MMX Thanks this.
  10. rogueunh
    rogueunh Road Train Member
    1,082
    22,200
    Jan 4, 2011
    They don't. There is a valve that changes position, redirecting the gas. It uses compressor to heat and cool, like a heat pump.
  11. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Our Carrier rep in Fargo has confirmed there is a programming issue with the last update on heat loads in very cold ambient temps. They’re going to come out and put older software on them to get us by for now. We have another in Fargo (sister load to mine) and one in Ohio having the same issues.
    KB3MMX Thanks this.
