Cargo Securement Training
Discussion in 'Questions From New Drivers' started by Buckeye 'bedder, Jan 18, 2011.
  1. Buckeye 'bedder
    Buckeye 'bedder Road Train Member
    1,043
    440
    Sep 26, 2010
    Nowhere
    A few companies with Flatbeds have 2-3 day securement training during orientation. Is it actually possible to learn cargo securement in only 2-3 days?
  3. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Cargo securement is really just alot of common sense. SO if you are lacking in that department all the training in the world won't help.
    What you will learn is important stuff like chain ratings, strap ratings, how many straps/chains needed for weight and/or length of material. They will most likely show you how to chain a coil and flat steel.
    You will most likely ride with a trainer for a few weeks to learn different things.
    rocknroll nik Thanks this.
  4. Buckeye 'bedder
    1,043
    440
    Sep 26, 2010
    Nowhere
    :biggrin_25525:
  5. Bumpy
    Bumpy Road Train Member
    6,529
    5,257
    Jan 27, 2009
    New Ulm,MN
    If I could learn how on my own,(true story)but not a very good typer....Certainly 2-3 days will be enough time.. Sometimes still,I get a load & wonder (?) How the f### am I gonna secure that?.? If any questions on how to,I ask the shippin boys,-( they do it day in & out) and have never had a problem in 7 years..:biggrin_2558:
  6. Rerun8963
    Rerun8963 Road Train Member
    3,917
    2,012
    Mar 30, 2006
    ova-hereee
    i was at Davenport, IA many years ago at the now defunct PST flatbed co.
    we were taught how to chain down John Deere farm equipment and pipes and pieces of the oil rig (derricks?...towers...?? whatever they were called) for the oil fields....took all of about 1 full week....then a trainer goes with you anyways....or at least, at PST one did...when you were a newbie....
    do not be afraid to put more straps or chains on the loads....it is after all YOUR responsibility.....don't be intimidated by other "experienced" drivers that say, "you got too much on thar boy"......
  7. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    Like Rerun said, it's better to go with a few more than a few less. One really important thing about tying stuff down is that you need to stop every so often and check your load and straps. Loads can shift and straps and chains can get loose. There are a lot of little tricks you will learn in tying stuff down. Like when you have pieces of lumber used for tying down left over. There are certain little things you can do to secure them to bed so that they won't go all over the place. Usually there is a place to hang chains and straps on your headboard. If not you can strap them on the bed. Nothing complicated but if you are shown how it will save you time.
  8. Buckeye 'bedder
    1,043
    440
    Sep 26, 2010
    Nowhere
    Check after first 25 miles, then again every 150 miles/3 hours (or if you stop before then)? Is that right?
  9. Flying Finn
    Flying Finn Heavy Load Member
    972
    556
    Jun 22, 2010
    Ontario, Canada
    Remember one thing.
    You will NEVER stop learning cargo securement. At least if you are a good driver and not BBR or a ST (like a certain someone from Ice Road Truckers that thinks securement of their load is someone else's job). :biggrin_25519:
    Deck work is a great job. You get to stay in shape and EVERY load is different.
    Working Class Patriot Thanks this.
  10. farmerleach
    farmerleach Light Load Member
    80
    28
    Dec 1, 2009
    I have never heard of someone getting in trouble from the DOT for having to many chains on a piece of equipment. Load securement is the responsibility of the driver. I'd be careful of taking advice from some of the shippers load out people. Some of the local guys make people with S*** for brains look pretty smart.
    I believe that there are regs on how many chains/straps are needed on a load, and spacing of the straps/chains. I'd get a copy of that, Mind you I haul grain so load securement for me is roll the tarp.
  11. 123456
    123456 Road Train Member
    10,555
    5,745
    Oct 22, 2010
    32179
    That's right.
    You can lern alot from a flatbedder,
    that hauls live chickens !!!!!
