Carbon Monoxide Meter in the Cab of your truck?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by LoneRanger, Sep 16, 2021.
  1. LoneRanger
    LoneRanger Road Train Member
    3,662
    9,446
    Jun 3, 2018
    Just wondering if anyone has ever put one inside their cab.
    I don’t like the fact that I’m idling or that the APU is on when I’m asleep. So I was wondering about putting one in.
    any thoughts?
  3. Arctic_fox
    3,864
    19,461
    Sep 16, 2016
    One of those personal prefrence things methinks. No harm in it i suppose.
  4. Rideandrepair
    17,212
    55,865
    Aug 8, 2015
    Not a bad idea. All the APUs around you at a Truckstop. Old way was, always keep a window cracked. Any exhaust leaks from diesel, be it through the floor, or shifter boot, isn’t enough to kill you. Unlike gasoline engines. Diesel produce much less Carbon monoxide. Now there’s gasoline generators, natural gas engines and generator APUs. We fell asleep with bunk vent open, woke up being parked next to a NaturalGas Truck idling. I could smell it. 2 hrs later my wife’s in the hospital with lung embolisms. I know it didn’t cause it, but think it broke the camels back, as I too had trouble breathing from it. I’ve had headaches before from a cracked shift boot, and leaking exhaust on my Truck. Won’t kill you, but studies show a constant low level has been found in some Truck Drivers. Think I’ll get one myself, plug it into the inverter. Had one save my family once, while on the road. Heat exchanger cracked on the furnace. Thank God I had one.
  5. supersnackbar
    18,602
    44,735
    Aug 19, 2007
    Your Town, USA
    I've used one for decades. Many years ago one of the drivers for the company I worked for had CO poisoning not once but twice. The shop found some sort of exhaust manifold leak from the factory, swore they fixed it. After he recovered from the 1st time, he jumped right back in the same truck, and within 2 weeks was in the hospital for it again. After that, I will never go without one, especially since more and more companies are using APU's (especially Carrier's with their straight out the side exhaust) or have the weed burner exhaust that stops between the sleeper and trailer.
  6. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    Every dpf equipped truck should have one. Especially grass burners I’ve had a 2015 t680 brand new try to kill me and a 2018 cascadia both grass burners I bought a detector after the 680 incident but never changed batteries my fault that’s why I got sick in the 2018 until I changed batteries and saw the readings. Both trucks the dpf was changed on warranty.
    Rideandrepair and LoneRanger Thank this.
  7. Antinomian
    Antinomian Road Train Member
    2,076
    3,242
    Feb 17, 2013
  8. LoneRanger
    3,662
    9,446
    Jun 3, 2018
    I picked one up and will be here tomorrow. Trucks a grass burner and the APU exhaust I don’t trust. I had a close call with a bad exhaust on my previous truck so it’s time to have one just in case.
    same issue with me I came close on previous truck, good thing we found it before I slept idling anymore.
    now with this one with a the APU finally fixed, but until I replace the exhaust I am going to need one.
    thanks for the feedback everyone.
    Magoo1968 and Rideandrepair Thank this.
  9. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    I have one in my truck.
    LoneRanger and Rideandrepair Thank this.
  10. terryt
    terryt Heavy Load Member
    736
    777
    Apr 27, 2009
    Get one made for a RV 12 volt. The one's made for a house can not the temperature swing's nor can they handle server cold. Every sleeper should have one all RV's do. I put one in every truck I own will not sleep without one.
    Magoo1968 Thanks this.
  11. LoneRanger
    3,662
    9,446
    Jun 3, 2018
    hmm, didn’t know that. I’ll look for one of them and cancel this one. Thanks for the heads up.
