Car hauler Q about the 5th wheel platform
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by Davo401, May 15, 2022.
  1. Davo401
    Davo401 Bobtail Member
    May 15, 2022
    Hey guys new to car hauling looking to buy a Cottrell 7 car trailer but found out that I have to custom modify my 5th wheel so it can be on top of my rear axle. I got a 15 Kenworth t680 and even if I slide my 5th wheel the way back it’s still not enough anybody familiar with this?
  3. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    ...you just have short wheelbase ...i doubt there is a solution ...you will be limiting yourself at some point
  4. Hammer166
    7,350
    26,445
    Aug 18, 2007
    ~8600+' and loving it!
    Very short nose on those trailers. It's a common issue.
  5. mslashbar
    mslashbar Medium Load Member
    599
    802
    Jul 22, 2009
    elizabeth,co
    You need to take it to a welding shop or frame shop and get them to extend your slide further back to where you need it. Also if you take your mudflaps off it will give you a little extra clearance.
  6. Kawinige01
    Kawinige01 Heavy Load Member
    863
    1,150
    May 30, 2016
    South Fla
    Its no custom work needed. You have to move the entire 5th wheel assembly backwards. If you have a sliding 5th wheel slide it all the way back. Cut the huck bolts and slide the entire assembly backwards until the 5th wheel is directly over the rear axle. Any shop familiar with car haulers can do that in 2/3 hours. You have to buy new bolts and if you still want to slide the 5th wheel a new hose for the slide release
  7. Kawinige01
    863
    1,150
    May 30, 2016
    South Fla
    Will post a few pics in a hour or so.
  8. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    You might get away with just reversing your slider plate if there’s a long enough rack on it.
