Can't Find The Difference Between 379's/389's (Peterbilt)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hoodoo Voodoo, Feb 1, 2017.
  1. Hoodoo Voodoo
    Hoodoo Voodoo Medium Load Member
    I'm sure this question has been asked a time or two but I cannot find any major difference between the 379 and 389 Peterbilts. All the research that I've been able to find the only difference between the two that I found was just cosmetic the hood sits a little higher on one. I believe the grill is different between the two and I believe there's a few other things. But I have not found anything major between the two. Like with Harleys the 883 Sportster is a lot smaller than the 1200 Sportster and of course the engines are two different sizes. I just figured that there would be some significance between the two Peterbilts. Am I really missing the boat on this? Any and all insight would be greatly appreciated thanks in advance
  3. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    You forgot about the single digit difference... Lol
    spyder7723 and Hoodoo Voodoo Thank this.
  4. crb
    crb Road Train Member
    1,676
    1,374
    Dec 1, 2009
    USA
    Pretty much just cosmetic. I think when they went to 389 is when they moved the mirrors to cab mounted as well. Grill and headlights are different
    dustinbrock and Hoodoo Voodoo Thank this.
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    There is a lot really, the basic cab shell didn't change, but a lot of other things did.
    The hood is taller to make room for the larger radiator needed for the DFP/SCR systems. Everything about the hood is different (grill, headlights, hinges, fenders, etc.). The frame rails are shorter a few inches and the bigger hood pushes the BBC measurement back a few inches (this makes less room from the back of the sleeper to the end of the frame (which sucks for us car haulers). The lighting is all multiplexed and they added a fuse block under the hood. The wiring is completely different compared to 379's. Steer suspension and all frame brackets are different. Different bumpers (mounting holes are all different). Air tank locations have all changed.
    Really there are too many changes to list.
    Oxbow, Toomanybikes, SAR and 3 others Thank this.
  6. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    A 1200 Sportster is the same size as a 883. Built on the same frame. Just different size pistons in the motor. But if you take a 1200 and a 883 both from the same year and park em next to each other, you can't tell the difference if you are far enough away to not read the emblems. Lol.
    Hoodoo Voodoo Thanks this.
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    When I bought mine he said it's now 131" up from 127" to still have room for dpf/scr and also have exhaust come out behind steps not through the right side step like they did in earlier 389 models...
    And if you rule out gliders you could say 379 = yellow motor and 389 = red motor...
    RefMata, Oxbow and Hoodoo Voodoo Thank this.
  8. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,470
    Nov 7, 2007
    Possum Booger, Alabama
    The 389 is way better because it's got ten more... well it's got ten more of something, I just can't remember what.
    All I know is that before the 389 came along, I was bald and not really popular with the ladies. Now I have a full head of hair and have to refill my Cialis prescription every three days, if you know what I mean. :cool:
  9. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
  10. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    Not as common, but 379's had red motors too. Don't rule out the grey motors on 389's, a lot of them have MX13's.
    Exhaust through steps? We have car haulers, we don't need silly steps, we have ladders :) . Here's a useless fact: 388's replaced short hood 379's, 389's replaced long hood 379's. But, you can order a short hood 389 making it identical to a 388. Why??? We have a mix of them all short 388 hoods, but some trucks are 389 models that are no different.
  11. lester
    2,915
    7,846
    Jan 2, 2012
    NW, Iowa
    Cab mounted mirrors came in 04 or 06 I think. Not positive on year but 379's did have them
    rank, Hoodoo Voodoo and crb Thank this.
