Can't find fridge fuse on my International
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ChuyG19, Jan 18, 2015.
  1. ChuyG19
    ChuyG19 Bobtail Member
    When I got my truck last year it didn't come with the fridge but has the switch in the dash and the wiring to the sleeper. That said I tried to hook up something other then a fridge and ended up blowing a fuse, I think. Now I have no power and the indicator light on the switch won't work anymore. I checked my fuses on the glove box but don't see any popped... How can I restore power to that circuit? 2007 International 9900i
  3. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    Check the fuse box in the cargo box on driver side. It should be top right near the door it controls most the fuses in the sleeper.
  4. ChuyG19
    I saw 3 fuses and some relays that are labeled "high speed relays", the 3 fuses are good. Am I looking in the right place? Fuses are in the cargo box on the drivers side but are in the top left corner.
  5. Fajo
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    Ya, sounds like the right area, might need to give international a call they can let you know right away where the fuse for that is.
    ChuyG19 Thanks this.
  6. ChuyG19
    thanks. Any particular way of getting a hold of international? My local dealer sucks when it comes to customer service...
  7. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    210
    Jan 31, 2012
    Green Bay Wi
    did you try google
    should be able to find a diagram
  8. 60Lugnutts
    60Lugnutts Bobtail Member
    12
    Fridge may not be a fuse but a breaker as it cycles power.
  9. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    I have a '07 9900 and the fuse for the fridge is on the fuse panel behind the glovebox. It is the 11th row from the drivers side, third spot down. It takes a 5 amp fuse.
  10. Sidelined
    Sidelined Light Load Member
    58
    16
    Sep 1, 2011
    northeast, MS
    Is there a power switch for the fridge from the factory? I dont have one any where on the dash labeled as such.
  11. Heavyd
    Heavyd Road Train Member
    7,804
    6,253
    Feb 4, 2009
    It is an option so your truck may not have it, but the switch location could be in the bunk control panel too.
