Can't find coolant leak dd15 cascadia freightliner 2018
Discussion in 'Freightliner Forum' started by Theleftmate, Nov 22, 2020.
  1. Theleftmate
    Theleftmate Bobtail Member
    10
    Oct 25, 2020
    So, I have been having this coolant leak for a month now. I've been in the shop 3 times for them to find it and each time they do all the tests and never find it. I replaced my heater core because I did smell in in the cab after replacing that. The smell did go away. But the leak continued. Now, I am at a point where I am burning a gallon a day of coolant while driving and while sitting. I'm heading to Allentown PA now and will be putting in in another shop any suggestions on what else to have them check would be great. Also, any freightliner dealer or shop that works on freightliner around that area who someone knows could find the leak would also be a huge help. My truck has a dd15 380k miles 2018 cascadia freightliner. Any information would be a huge help thank you ahead of time
  3. reeferwrencher
    reeferwrencher Medium Load Member
    556
    1,474
    Aug 4, 2018
    If you can't see any leak then maybe you have a bad head gasket and you're burning coolant.
  4. 86scotty
    86scotty Road Train Member
    4,375
    11,611
    Aug 27, 2017
    Appalachia
    Get yourself some coolant dye and a blacklight flashlight off Amazon. I did this and solved all my coolant problems. That is, of course, it it's not internal.
  5. 25(2)+2
    18,749
    45,385
    Sep 18, 2006
    the road less travelled
    There is a small line running alongside the engine from the back up towards the surge tank, not sure where it starts and ends, but it leaks intermittently, the FL(WS) shop knew about it and replaced the line, the lease shop was unable to find the leak in 2 tries. 3 times, lost enough coolant to trigger shutdown, but never found a puddle and it wasn't being burned.
    The replacement line is metal, I believe.
    MAKSTRANS and Hammer166 Thank this.
  6. AModelCat
    154,368
    Anybody test the EGR cooler? Be my first go-to if there was no external leak.
  7. 25(2)+2
    18,749
    45,385
    Sep 18, 2006
    Wouldn't that lead to burning coolant?
  8. AModelCat
    154,368
    Yep it'd be putting coolant into the EGR stream. EGR cooler is typically a higher-fail item than a headgasket from what I've seen. Generally speaking of course.
  9. 25(2)+2
    18,749
    45,385
    Sep 18, 2006
    That line I mentioned is very high fail, from what little they tell the idiot driving, meaning me.
  10. NorCenArk
    NorCenArk Light Load Member
    76
    35
    Mar 31, 2011
    Russellville, AR
    On the driver's side of engine, there is about a 3/4 black plastic line running from near top of engine to air compressor. There is also a short one from air compressor back to block. These are prone to leak, you are at the mileage they begin. Pay close attention around the clamp just above the oil filter.
    Hammer166, BoostedTeg and 25(2)+2 Thank this.
  11. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    You can usually tell if it’s that by pulling the hump hose off the intake side and seeing if there’s any moisture in there I believe.
    AModelCat and 25(2)+2 Thank this.
