Canadian Elog Question
Discussion in 'Canadian Truckers Forum' started by AModelCat, Nov 19, 2018.
  1. AModelCat
    154,534
    I keep reading that a backup paper log is required in the event of an elog system failure. I'm not having much luck with finding any regulations stating that they are required or not here in Canada. My supervisor doesn't seem to think we need to keep a paper log in the truck but he won't be the one getting the ticket.
    Nothereoften and Jazz1 Thank this.
  3. SteerTire
    SteerTire Road Train Member
    1,414
    2,346
    Nov 5, 2018
    Behind the wheel
    I’m not Canadian. But can certainly answer your question.
    Keep a logbook on the truck. Simple as that. You may never use it. But, if your elog fails. How are you going to log your hours if you don’t have one?
    You could use a notebook. But why? Truthfully it only cost a couple of dollars. And it’s only a one time expense hopefully. So why not?
    AModelCat Thanks this.
  4. AModelCat
    154,534
    Totally noob question but where would a guy buy a logbook?
  5. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Any of the truck stops around Edmonton, or at Grassland. Probably even the Petro-Pass in Ft. Mac.
  6. AModelCat
    154,534
    Probably be easier for me to just go and buy one. Is it actually a requirement in Canada to have a paper logbook when running elogs?
  7. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    You're right, he's wrong; here's the rule.
    Commercial Vehicle Drivers Hours of Service Regulations (SOR/2005-313)
    83 Use of Electronic Recording Devices
    A driver may use an electronic recording device for recording their duty status if
    (h) the motor carrier provides blank daily log forms in the commercial vehicle for the driver’s use.
    - https://laws-lois.justice.gc.ca/eng/regulations/SOR-2005-313/page-5.html#h-42
    BigHossVolvo, tinytim and AModelCat Thank this.
  8. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    The easy way to remember is you ALWAYS have to be able to produce proof regarding your work status. If the eLog is dead, how else can you log?
    Nothereoften, AModelCat and SteerTire Thank this.
  9. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    I think I found the problem. Subparagraph (h), as posted above, is missing from the published version of NSC Standard 9 as is available on the CCMTA website. The version I posted is from the federal Department of Justice website and is the official consolidation of the Act. That is one reason why I always try to go to the source.
    ETA: I have sent an email to the CCMTA asking for correction or clarification.
    magoo68 and AModelCat Thank this.
  10. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    Think about it. If we did not require a logbook as backup then we'd all be running a broken ELOG:D
    25(2)+2, Canadianhauler21 and not4hire Thank this.
  11. Canadianhauler21
    Canadianhauler21 Heavy Load Member
    842
    1,616
    May 15, 2017
    My Elog stopped working this trip to the US, the screen stopped working. Having a real joy on these paper logs ;)
    upnorthwpg and Jazz1 Thank this.
