Can you take Cdla test with dually and trailer?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by 2ndAct, Oct 1, 2016.
  1. 2ndAct
    2ndAct Bobtail Member
    20
    5
    Oct 22, 2014
    Suffern,NY
    I have my Cdl a and my son has been driving a dually with trailer that is less than 26,000 gcwr. If we had a trailer that put the gcwr above 26,000(he does not have a Cdl). could he take his Cdl a road test with that setup? Would be a quick process since he already knows how to drive that instead of a semi.
    Thanks
  3. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
  4. Observer1
    Observer1 Light Load Member
    108
    492
    Aug 6, 2016
    If the GCWR is over 26,001 and the trailer is over 10,000 GVWR then yes. They will give you an air brake restriction.
    Badmon and brian991219 Thank this.
  5. 2ndAct
    20
    5
    Oct 22, 2014
    Suffern,NY
    Nice. Rules same in all states on this? I'm in New York
  6. 2ndAct
    20
    5
    Oct 22, 2014
    Suffern,NY
    Response below said yes with air brake restriction. You say nope.
  7. Observer1
    108
    492
    Aug 6, 2016
  8. Observer1
    108
    492
    Aug 6, 2016
    They should be. The FMCSA dictates what qualifies as a CMV and what is required for each license class. The feds also made it manditory for the air brake restriction because guys were taking their tests in a pickup/trailer combination and then driving a semi. FMCSAs website explains the air brake restriction.
  9. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Yes you can. Restrictions will be no air brakes and no semi. Air brake reason is obvious, semi restriction is because it is a gooseneck and not a 5th wheel. This is exactly how I started. He will still have pass the written combination test.
  10. FarmerTransportation
    FarmerTransportation Light Load Member
    130
    66
    Dec 26, 2013
    Pittsburgh, PA
    That's what I did. As said, air brake and semi restriction.
  11. TruckDrivingtn
    TruckDrivingtn Light Load Member
    246
    236
    Sep 8, 2016
    Maryville Tn
    I initially got My cdl this way with out the airbrakes.. 3500 Dually with a 44 ft featherlite....
