Can you drop a loaded 42,000# trailer on asphalt?
Discussion in 'Experienced Truckers' Advice' started by ModularMike, May 2, 2008.
  1. ModularMike
    ModularMike Bobtail Member
    9
    Midwest
    just as the title says. I just dropped the trailer for the weekend and it wasn't on a cement pad... (approx. 42,000# in traier)
    Is this the right place to put this question??? lol???
  3. heyns57
    heyns57 Road Train Member
    2,209
    1,011
    Dec 30, 2006
    near Kalamazoo Speedway
    Most asphalt drop-lots have cement strips for the support legs. If the asphalt is at least 6 inches deep and old, it should be safe to drop there. If the asphalt is new and only 4 inches deep, the sand shoes will leave an impression unless their footprint is expanded with a couple of 2x8s. The ambient temperature is also a factor.
  4. ModularMike
    9
    Midwest
    it's in a 4-wheeler parking lot, the drop pad was full.
  5. panhandlepat
    panhandlepat Road Train Member
    3,255
    2,243
    Jan 12, 2007
    thats what i was thinking! also the base material under the asphalt.
  6. jlkklj777
    jlkklj777 20 Year Truckload Veteran
    1,871
    1,090
    Oct 1, 2007
    Duncannon, Pa
    You may have to call a wrecker to lift that trailer back up once the legs punch through that asphalt. I have seen this happen a few times in my travels and so I carry some extra wide boards to spread the weight out before dropping the trailer. I like rough cut 2x10's for dropping a heavy trailer on any questionable area wether it be sandy, muddy, or blacktop.
  7. panhandlepat
    3,255
    2,243
    Jan 12, 2007
    if you have air dump suspension it may not be an issue
  8. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,980
    Apr 4, 2007
    I know a guy that dropped a loaded refer on asphalt. It sank about 12 inches into the pavement. He had to have a wrecker come out.
  9. panhandlepat
    3,255
    2,243
    Jan 12, 2007
    OUCH!!!!!!!!!!!
  10. jlkklj777
    1,871
    1,090
    Oct 1, 2007
    Duncannon, Pa
    If you take the time to stop with your frame under the nose of the trailer and then watch to see wether the ground will hold up then yes you may be able to "catch it" before it sinks too low. I have seen trailers that punched through blacktop and kept sinking until the nose of the trailer was touching the ground.
    If in doubt use some heavy wood boards under the landing gear first or better yet find an alternate spot preferrably on a reinforced concrete pad.
  11. Roadmedic
    18,951
    8,980
    Apr 4, 2007
    I always carried 4x4's. You could use them to also help on stubborn tandems.
